Old 01-20-2009, 10:16 PM   #1
redrider036
Red face Where do I start? (sorry kinda long)
Hey, thanks to everybody who is willing to help a newbie out here. I have a 1970 k10 4wd half ton. It is parked on my dads property in Minnesota and I will be picking it up this summer. While i was up there this past winter, I checked the vin and there is a C instead of a K. the truck is 4 wheel drive so I supposed parts where interchanged. Anyway, I am so overwhelmed. The box is rusted out, along with the rockers and inside of the doors about a half inch on the floor. the rest of the floor is good although I have not looked underneath the truck yet. I am renting my house right now so i am concerned about doing too much cutting or welding in my garage, but this truck WILL get done, it means a lot to me. The truck ran and drove great when my Dad parked it, of course, that was six years ago. When I get this truck down here, any opinoins of the best way to get it started would be very appreciated, and I do not take offense to constructive criticism either. I am considering looking for someone who is looking for side work and getting a hand there. Thank you for your time all!
redrider036 is offline   Reply With Quote
Old 01-20-2009, 11:56 PM   #2
68350
68350's Avatar
Re: Where do I start? (sorry kinda long)
Well, for starters I would check all the fluids and make sure everything is on the up and up. If everything is good, you might consider taking the gas line off(rubber) and running a hose to the metal gas line(so it's good gas). If it has points, they might be bad so if it trys to start and doesn't, that might be the first thing to check. As far as rust in concerned, keep an eye out and you might find a cheap parts truck that doesn't have much(kinda hard in minnesota, land of 10000 salt trucks). Have fun with it!
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 01-20-2009, 11:57 PM   #3
tim21391
tim21391's Avatar
do what i did... order parts little by little... and make sure you got plenty of time to work on it..
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 01-20-2009, 11:57 PM   #4
clay68c10
clay68c10's Avatar
Get it running and worry about the rust later.
Sounds like a cool truck!
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 01-21-2009, 12:29 AM   #5
hilandr452
hilandr452's Avatar
Dump the oil before you start it and check for water in the pan. Pull out the plugs and check for rust on the electrodes. When you pull out the plugs, pour in a little marvel mystery oil, or whatever your grand dad says to use in each cylinder. Dump the radiator and check the fluid for oil. Dump the fuel tank and replace with new gas. Make sure there are no mice in the air cleaner or carburetor. ( no kidding ) If it passes all these tests and the points are good, fill up yer fluids and replace the oil filter with a non Fram type filter (Fram is terrible, there's a thread on that somewhere here) , old oil filters after sitting for years could easily be distributed throughout your oil galleys. Crank her a few times with the coil wire off to distribute the new oil and get things lubed up and the carburetor primed (you may need to manually prime the carb). Let 'er rip brother and enjoy the new ride!!
Dan
Dan Smith
Colorado Springs, CO
71 GMC Custom Camper "Longhorn" 454, TH400
73 Chevy Camper Special (Yes, it's badged a camper special) Flat Bed Motorhome conversion 454, standard tranny
"DON'T TREAD ON ME !!!"
My Project: http://www.picturetrail.com/sfx/album/view/20829244 , http://www.picturetrail.com/sfx/album/view/24654442
hilandr452 is offline   Reply With Quote
Old 01-21-2009, 02:44 PM   #6
redrider036
Smile Re: Where do I start? (sorry kinda long)
Thanks guys. The truck currently has a 305 in it and has been converted from a manual (three on the tree) to an automatic. Before I moved to Arizona I pulled off the carb and sure enough there was a mouse nest in the intake, lol. I can't honestly say whether the transmission conversion was done properly or not, but my Dad drove it for some time after the work was done. I am probably gonna have somebody look at the truck and get it going for me, I found a guy on craigslist who's nephew I went to elementary school with- small world huh? He seems to know his stuff and I just don't have to time to fly up there and work on the truck and come back home....I have a job and no time to be up in MN at this point. Here's the crazy part. My intentions are to drive the truck back to AZ. I always like a good adventure! I will only do this if the truck is in ok shape to do it upon further inspection, only time will tell really. Yea, I got a few screws loose upstairs lol.
Old 01-21-2009, 03:13 PM   #7
Chris H
72 C30 Trailer Queen
Chris H's Avatar
Just to throw in a few cents here:
Unless you have a complete and total love for this exact truck, hauling (or trying to drive) a rusty MN truck to AZ doesn't seem like a great idea to me.
I have lived in both places; was in Phoenix and now near Rochester (I would be glad to help you on this end where I can if it is reasonably close). Do yourself a favor and find a truck locally. You can probably buy a decent driver truck for what it would cost you to come to MN and take one home.
Either that, or invest in an oxy/acetylene torch, a right angle grinder with a good selection of wheels, a sawzall and lots of penetrating oil. Dont forget a good pair of work gloves and keep your tetanus shot current. You are going to need all these things just to change 1 shock absorber. Now multiply that by every bolt that holds your truck together... hear me know and believe me later! You will hate yourself!
Now I am not oblivious to sentimental attachement, but if dollars and sanity mean anything to you
Chris H
72 C30 133"
72 C30 157" flat-dump
69 C10 short fleet
71 ElCamino
2000 K2500 crewcab shortbed (sold, sorry old friend)
2005 GMC 2500HD shortcrew Duramax
2006 K1500 RCSB
and a couple other projects/parts
Chris H is offline   Reply With Quote
Old 01-21-2009, 03:41 PM   #8
redrider036
Yea, I have heard that a lot. Everyone thinks I am crazy and rightfully so....even my Dad. I will be working on this truck. Thanks for the advice though.
Old 01-21-2009, 04:39 PM   #9
wHATANERD
wHATANERD's Avatar
You haven't mention why your dad parked the truck in the first place. I would assume if it was running decent he would probaly still drive it.
1969 C/10 Longbed undergoing rebuild.
Old Chevy's Never Die, They Just Rust Around The Edges
wHATANERD is offline   Reply With Quote
Old 01-21-2009, 04:49 PM   #10
redrider036
He has an 86 Silverado that he uses now for hauling wood. His intention was to fix up the '70 in time. He has a '67 Cutlass and a '64 Impala that need work as well. My dad is getting older and does not have the time anymore. He passed the truck along to me.
Old 01-21-2009, 05:39 PM   #11
Arizona oldguy
Arizona oldguy's Avatar
Kinda have to agree with they guy in Rochester, I live in the other place and it is not that hard to find one here, on the other hand I understand where you are coming from wanting to fix that one. Have you thought of a tow dolly, adventure is adventure but a nightmare is a nightmare, and you do have some time constraints. Old trucks can be hard to drive 2000 miles. Good luck enjoy your adventure and the work.
Arizona oldguy is offline   Reply With Quote
