Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-21-2009, 02:37 PM   #1
ole6320
HP estimate 406
Its a 400 + .030, forged dome pistons, solid lifter cam and lifters, the specs are, .560/.570 lift, .268/.270 @.050. It has 441 heads with some port work done, 1.94 intake, 1.60 exhaust, valves, 1.5 wide body roller rockers, stud girdles, double roller chain, hi volume oil pump, miledon pan w/ baffles, victor jr. 2 intake manifold, 750 carb, what do you guys think its putting out, compression is around 12.5 to 1
ole6320 is offline   Reply With Quote
Old 01-21-2009, 08:46 PM   #2
nxtruck
nxtruck's Avatar
Re: HP estimate 406
How much porting, and by who? Without any more info, I'd guess around 440-460.
Chris
1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas
7.02 @ 95.8, 1.45 60'
1965 Chevy C10 LWB, 355 sbc, TH350, daily driver
nxtruck is offline   Reply With Quote
Old 01-21-2009, 11:17 PM   #3
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: HP estimate 406
Nice set up . Change the heads and it will be alot more . A 210 AFR wil do wonders for that combo .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 01-22-2009, 10:22 AM   #4
ole6320
Re: HP estimate 406
Thanks, im interested to see how the victor will do on the street, you think I might be better off with a performer rpm? or something of that sort
Old 01-22-2009, 11:42 AM   #5
ProStreet71
Re: HP estimate 406
Why so much compression for the street? You will not be able to run pump gas with this much compression. You definitly need more head than what you have. That 1.94 valve is restricting it for sure. Like hotrod 80 said, the AFR 210 heads will do wonders for your motor. IMO they are the best out of the box head you can buy for the money. The 400 has plenty of low end torque so you can run the victor and never know you lost anything down low on a motor like this.
ProStreet71 is offline   Reply With Quote
Old 01-22-2009, 01:11 PM   #6
ole6320
Re: HP estimate 406
I have it set up to run on e-85 so thats why it has the high compression
Old 01-22-2009, 01:37 PM   #7
primered_junk
ASE master tech/machinist
primered_junk's Avatar
Re: HP estimate 406
The E-85, will work fine, not as good for making power as methanol, but it is awesome to see some one thinking out of the box. Ported 441's are not bad, but that valve size is killing your combo. I agree with NXtruck, somewhere in the 460 hp range. Very close to a combo I ran forever mine had less compression, and was a blast to drive on the street.
"I sit here and I pray in my broken down Chevrolet....."
primered_junk is offline   Reply With Quote
Old 01-22-2009, 02:17 PM   #8
ole6320
Re: HP estimate 406
Yea Im excited to see how it is on the street, and plus e-85 is cheap aound here and can be found at alomsot every gas station. My truck is just going to smell like corn! I actually bought the motor as it is now for 1000, it was complete minus carb, which there is a company around here that sells and converts e-85 carbs for around 650 dollars with tuning, so thats not a bad deal I dont think
Old 01-22-2009, 02:38 PM   #9
primered_junk
Re: HP estimate 406
That is cool, keep us posted!
Old 01-24-2009, 12:59 PM   #10
ole6320
Re: HP estimate 406
now onto the transmission, how much of a torque convertor do you think I should run, the rear end has 3.73 gears, trans cooler also? its a th350 that is getting rebuilt
1986 Chevy C-10 2WD Long Box
406 SBC 12.5/1 compression
E-85 monster!
Old 01-24-2009, 01:14 PM   #11
shortbed70
shortbed70's Avatar
Re: HP estimate 406
Street 22-2500 or drag 32-3600. Keep in mind depending on the torque output of your motor #s will vary. The vic intake won't really make power until around 2500 and your cam probably around the same or higher and get the biggest cooler you can fit.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 01-24-2009, 02:59 PM   #12
djracer
djracer's Avatar
Re: HP estimate 406
I would lean towards a little looser convertor 3000 to 3200 I always run a trans temp gauge to watch the temp.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 01-25-2009, 07:44 PM   #13
crossy
Oh,you can't buy that new
crossy's Avatar
Re: HP estimate 406
not meaning to be the 'doubter' as i agree with HP figures, but those heads are 76cc. what are those pistons to make 12.5 to 1. those piston'ratings' are based on a 64cc combustion chamber usually. crossy
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
Old 01-25-2009, 11:35 PM   #14
PhilaTruck
Right on the line, baby!
PhilaTruck's Avatar
Re: HP estimate 406
76 or 80cc according to mortec-
Sounds like a cool project and one lumpy cam.
We don't get much e-85 here in Philly.
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly
Click and scroll down for site vendors!
Subscribe here!
PhilaTruck is offline   Reply With Quote
Old 01-26-2009, 06:28 PM   #15
ole6320
Re: HP estimate 406
yea thanks guys, it should be a run motor, all I really need to do is get the e-85 carb, new fuel pump and she should be good to go, unless Im forgetting something! Gonna get it to the dyno here in the next month or two
E-85 monster!
Old 01-26-2009, 06:37 PM   #16
crossy
crossy's Avatar
Re: HP estimate 406
GOOD LORD Todd!!, you live right on top of 4 different refineries. Just run a siphon hose down the storm drain in front of your house and probably get hi-test for free
98 Vortec project.
94,3500,6.5L 4L80
Old 01-26-2009, 06:43 PM   #17
ole6320
Re: HP estimate 406
is there a way to tell what size cc they are? I know they have had some port work done to them
E-85 monster!
Old 01-26-2009, 06:58 PM   #18
PhilaTruck
PhilaTruck's Avatar
Re: HP estimate 406
A machine shop can do that. Otherwise, it involves a level stand, a graduated pipette, and some liquid. My shop port-matched mine- some were bigger than others.
Crossy: So that's what that smell is!
Subscribe here!
Old 01-26-2009, 08:48 PM   #19
Super73
Super73's Avatar
Re: HP estimate 406
Do you have a company/grind number. I'd be curious to know what the intake closing point is. That would really determine dynamic compression and if it would be usable with pump gas.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 01-27-2009, 11:08 AM   #20
ole6320
Re: HP estimate 406
I believe it is a crane cam, the guy I bought it from used it at the drag for three runs, he said it dynoed at 531 with e-85 in it
E-85 monster!
