Old 01-21-2009, 06:25 PM   #1
mleeb
mleeb's Avatar
Unhappy 402 engine problems???
My BB 402 idles ok but a low thumping noise is present. It increases frequency and volume as rpm goes up. Here's the story of how the noise started... I installed a set of summet headers on the engine a few months ago and the truck sat for a few months till I saved enough to do exhaust( dual 40 series flowmaters with H pipe by the way...) After and before exhaust mods the engine ran good. I drove the truck after finishing the exhaust with no problems until the new headers heated up and melted through some of my spark plug cables...then it ran like crap because the ignition was sorting all thre time. I replaced the cables with a new set with 45degree boots and fiberglass boot covers and replaed all spark plugs. After all that the noise is there...what do you think it is ? what did I break?
P.S. I'm running a MDS 6AL ignition if that helps-
71 Chevy C-20 Fleetside
Stock 402 BB-Summit Headers-700R4 Trans
Dual 40 series flowmaster w/ H pipe
Edelbrock 2161 intake & 1411 Carb
mleeb is offline   Reply With Quote
Old 01-21-2009, 07:07 PM   #2
jhow66
jhow66's Avatar
Re: 402 engine problems???
Sounds like # 5 & 7 plugs wire are crossed.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 01-21-2009, 07:25 PM   #3
Kayotic
Kayotic's Avatar
That would make it my guess, re-check your plug wires.
Atlanta Craigslist
Hurst Indy Pickup Truck 3-Speed Shifter - 5010016
Kayotic is offline   Reply With Quote
Old 01-21-2009, 08:38 PM   #4
mleeb
mleeb's Avatar
nope...I re-checked all wires right. 1-8-4-3-6-5-7-2 firing order...does it matter where you put #1 wire on distributor? because mine goes #2 just left of Hei coil then 1-8-4-3-6-5-7.
Upon further checking.. with truck in park and idle it's a faint clicking then still faint if I rev engine in park. In any gears it gets louder, like a brushing noise..like a belt falling apart and flapping around sound...
I also recently swapped trannys from a 350 to 700r4
Old 01-21-2009, 09:08 PM   #5
arkie726
arkie726's Avatar
Make sure your torque converter isn't loose on the flex plate.
arkie726 is offline   Reply With Quote
Old 01-21-2009, 09:08 PM   #6
haysonj
haysonj's Avatar
Check to make sure the bell housing bolts are all up tight and there is no gap between the engine and bell housing. It sounds like the torque converter is hitting something.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 01-22-2009, 01:01 PM   #7
mleeb
mleeb's Avatar
I looked at trans bell housing, it all seems secure...no gaps or loose bolts. I'm gonna have shop that installed tranny check it out torque converter today.
Thanks for your help!!
Old 01-22-2009, 05:35 PM   #8
ETsC10
Hand Crafted C-10
ETsC10's Avatar
You might want to do a visual under the hood when it's dark...see if you have arcing/cross-firing.
ETsC10 is offline   Reply With Quote
Old 01-23-2009, 12:27 PM   #9
396C20
396C20's Avatar
I know this might sound crazy but.. tighten up the header bolts or make sure the header gasket is still good. My buddy's engine started making a noise that we swore was valvetrain but ended up being the gasket was blown out and the headers were loose.
69 Chev C20 396 T400 Dana 60 3.54 A/C Daily Driver - Stolen
67 Chevy C20 CST
396C20 is offline   Reply With Quote
Old 01-23-2009, 12:37 PM   #10
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 01-23-2009, 03:52 PM   #11
chev-obsession
chev-obsession's Avatar
that same thing happened to me a couple of days ago
chev-obsession is offline   Reply With Quote
Old 01-23-2009, 05:02 PM   #12
woodridge
woodridge's Avatar
Sounds like the Torqe Converter may have blown a thrust bearing.
SEMA Network- Protect our Hobby!
71 C30 in pieces, starting to come together.
Click here for A Place For Tennessee Truck Enthusiest To Meet
woodridge is offline   Reply With Quote
Old 01-23-2009, 09:06 PM   #13
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Exhaust leak can sound just like a click or valve train noise...just got a new one in my exhaust that has previously been running fine for three years. was worried that I had a valve train issue until I listened closer.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
