Old 03-05-2003, 04:15 AM   #1
lost wages
lost wages's Avatar
will these wheels fit????
i got a buddy that works at a tire store who can get me a deal on wheels, the ones i like are boss 304 wheels, the problem is they only come in 18x9. I want 18s but will a 18x9 wheel on the front of a bagged truck cause problems? what tire would work and look right on this size of wheel? back spacing? thanks.
lost wages is offline   Reply With Quote
Old 03-05-2003, 04:19 AM   #2
lost wages
lost wages's Avatar
heres a pic, on the offset it says +14mm?????????
Old 03-05-2003, 04:32 AM   #3
Alexis
Member since 2000
Alexis's Avatar
the back spacing on that should be 5 inches if i'm correct to fit. 14mm should come out to be 9/16 i think
Alexis is offline   Reply With Quote
Old 03-05-2003, 11:40 PM   #4
Dreaminator
Dreaminator
Check your front wheel wells as well. I am assuming you will run 35 or 40 sidewalls. If you remove the front wheel wells you will also probably need firewall attached hood hinges. I think you can adapt some 1980 and 1990 dodge hinges. Be careful of the off set (back spacing). Turn your front hard to either side and you will probably hit your stock shock. That said, I have seen a slammed 72 with 22s in suburban Chicago.
The Dreaminator
Daily Driver 1971 Cheyenne 10 Lwb Tilt/Tac 402 .030 TH400.
Dreaminator is offline   Reply With Quote
