01-21-2009, 08:55 PM | #1 |
Clearance Lights
Does anyone know if they are making repoductions of the wiring harness going from the light switch up to the clearance/running light on top of the cab?
01-21-2009, 09:03 PM | #2 |
Old Skool Club
Re: Clearance Lights
Don't know, but try www.wiringharness.com. This is M&H Fabricators in CA. They make reproduction wiring harnesses for these trucks with correct colors, guages and connectors. They, in my opinion, are your best bet.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
01-21-2009, 09:11 PM | #3 |
Thanks for the response I will check them out. I may just pull the old harness out and make a new one myself.
01-21-2009, 09:32 PM | #4 |
ChevLoRay, I just checked them out, according to their catalog they make make clearance/ marker/ running lights starting in 1973 and newer. I will give them a call tomorrow and see if they can make the harness for 72 and older trucks.
Thanks again. |
01-21-2009, 09:32 PM | #5 |
1967 Shortbed "Project Patina"
Crumley where does your wiring go thru the top of the cab on your truck. I think my truck had original clearance lights from the factory. When i bought my truck it had four or five on the cab( I cant remember it has been so long since I took them off) and one wire going up threw a small hole in the top left windshield portion of the cab. I hated to get rid of them but they had been leaking for years and rusted out the drivers side floorboard of the truck. As soon as i bought the truck i took them off. If where my wiring went threw the roof is correct I will look for another set and reinstall them.
01-21-2009, 09:32 PM | #6 |
Too many projects
How do you get the wiring up to the lights? I'm trying to put a digital gauge above the mirror and can't find a route to put the wires. Thanks in advance.
EDIT: My bad, question answered as I asked. Good to go.
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" Last edited by lowrollin70gmc; 01-21-2009 at 09:33 PM. |
01-21-2009, 09:59 PM | #7 |
lowrollinGMC and tgriffin27
The wiring to the 5 marker lights on top of the cab is routed thru the left side A pillar. Starting at the light switch it enters thru a hole just above the left foot well fresh air vent, up the center of the left A pillar. The way to access the wiring comming up the A pillar is thru the hole that the sun visor spring/pivot slids into (remove the left sun visor) and the hole in the top of the cab for the marker lights. This is going to be a bit of a pain getting this wiring out to repair or replace and pulled back in. I plan on tapeing a pull string onto the marker light wiring so while the wires are being pulled out there will be a string being pulled in the place of the wires. When the repairs are made I will tape the repaired wires to the pull string and hopefully pull the wires back into place. I hope that made since. |
01-23-2009, 09:05 PM | #8 |
It made alot of sense! Thanks for the info and when it gets warmer I am going to look and see if maybe I have some original wiring going up the A Pillar. The wiring I took out wasn't original at all but the holes in the cab seemed to be original and all where cut the same.
01-24-2009, 05:27 PM | #9 |
I think Lmc makes a roof clearnce/marker light harness for the 67-72 chevy/gmc trucks.I rember looking at them for my truck,but i would like to see what they look like on the truck before i by a set. The trucks that came with clearance lights form factory didnt the roof have like pockets for the lights to set in
01-24-2009, 05:36 PM | #10 |
It is extremely easy to reproduce the light harness yourself. If you have the old one to copy, only 2 wires, in a circuit.
Excellent info/idea for the string left behind to follow when you replace the new wiring harness.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
01-24-2009, 07:59 PM | #11 |
10-4 LMC does have some clearance light repo parts but I didn't see a complete harness, so I ordered some light bulb ends and will repair my existing harness.
I am having to repair the wiring harness due to my stupidity while mechanically wire wheeling seamsealer out of the gutters..... The truck cabs that came factory with clearance/marker/running lights have pods stamped into the profile of the roof. I have attached some pictures hopfully the roof marker light pods can be seen. |
