Old 05-24-2008, 04:29 PM   #401
copywritten
CopyWritten
copywritten's Avatar
Re: Project Lemon Drop: anything but stock!
Originally Posted by randomhero472 View Post
Im a taller guy (6'3") and ended up selling my seats from an 06 truck, they just felt way to big in that cab, but they are damn comfy
Thats what I am talkin about. I am all about comfy! I was getting ready to order a new tilt column, but now I am gonna wait till I get those seats in to see if I need a shorter one.
copywritten is offline   Reply With Quote
Old 06-05-2008, 05:11 PM   #402
jugernot
Life, Be In It.....
jugernot's Avatar
I'm taking a break from the wiring, since Kevin finished welding up my coverted blazer gas filler tube and adding a bit to my blazer tank. I painted, installed and connected all the fuel and vent tubes. It turned out really nice. I got the idea for the filler tube from Livrat another member and modified it a little.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 06-05-2008, 05:13 PM   #403
jugernot
Life, Be In It.....
jugernot's Avatar
There are some more pics with the tubes attached
Old 06-05-2008, 05:23 PM   #404
Rokcrln
Rokcrln's Avatar
Dat looks puurdy
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 06-09-2008, 12:26 AM   #405
pcorriveau951
pcorriveau951's Avatar
Jugernot, truck is looking great, i was just playing with my truck this weekend trying to plan out the wiring and thought about puting the fuse block in the kick panel vent, then saw you did it, how funny. but i have a few questions for you, how are you planning on routing the wires from the fuse panel to the engine, headlight section? in plain getting all wires to outside the cab? did you still use the painless wire disconnect the normally goes thru the firewall?
Do you happen to have a picture of the the fuse panel installed? if your willing to share if not i understand, i have a couple of secerts that i want to keep on my truck as well until its done.
Thanks,
Phil
pcorriveau951 is offline   Reply With Quote
Old 06-09-2008, 09:52 PM   #406
jugernot
Life, Be In It.....
jugernot's Avatar
Thanks,
Phil
I used an 18 curcuit universal non GM column ingition harness from painless. (pictured below). it does not have the firewall connector like the OEM style harness. its all one piece.
If you are going to put your harness into the vent, make sure that you have the turn signal flasher fuses install to check fitment ans accessiblity.
As for the wires the go into the engine compartment, Kevin put a hole through the kick panel. I do not have a picture of it but it is oposite the kick panel vent opening some where around the area shown by yellow in the picture below.
I have no problems sharing, in fact a couple of memebers have used our idea for the gas filler door.
I hope this helps you out.
Old 06-09-2008, 09:58 PM   #407
jugernot
Life, Be In It.....
jugernot's Avatar
pcorriveau951,
Just another thought, you could probable also put the harness through this area, but of course on the drivers side.
Old 06-09-2008, 10:41 PM   #408
pcorriveau951
thank you for sharing, im trying to decide which way i want to go, i hate the look of wires im trying to figure a way to get it all done with very minimal amounts of wires being seen anywhere in the truck, going to be alot of work but i think it will be worth it.
Old 12-02-2008, 01:42 AM   #409
crey
Any updates on this build guys?
crey is offline   Reply With Quote
Old 12-04-2008, 12:43 AM   #410
jugernot
Life, Be In It.....
jugernot's Avatar
Sorry the only update I have is that I had a vistor today, who said my paint was to loud and gave me a ticket.....................
Old 12-04-2008, 12:57 AM   #411
Hart_Rod
Hart_Rod's Avatar
Hart_Rod is offline   Reply With Quote
Old 12-04-2008, 01:27 AM   #412
Rokcrln
Rokcrln's Avatar
Dude I think that dam Cop parked on your Smart car So is that the new daily commuter?
Kevin
LFD Inc.
Old 12-04-2008, 12:38 PM   #413
jugernot
Life, Be In It.....
jugernot's Avatar
Kevin
LFD Inc.
I wish, just show and tell as the little one's school
Old 12-04-2008, 02:50 PM   #414
paintpyro
paintpyro's Avatar
I didn't see that paint option when I got my Magnum lol
70 shortbed stepside
"Schleprock"
350 w/TH400
rallys and BFGs
-We can rebuild it, we have the technology-lower,shinier,faster
paintpyro is offline   Reply With Quote
Old 01-20-2009, 10:49 AM   #415
drag_72
Ready to go fast!!
drag_72's Avatar
jesse james the bike builder once said : "international color for scared is yellow" lol just a thought but nice truck man lol
454 block .30 forged aluminum pistons
steel crank
valve job
Holley Strip Dominator intake
1030cfm holley carb, 250 plate shot
roller rockers Erson Solid cam split duration 307/310.
.575/.595 lift
milodon oil pan
fab. aluminum valve covers
4 bolt main splayed anodized caps
all studded
drag_72 is offline   Reply With Quote
Old 01-22-2009, 06:20 PM   #416
jugernot
Life, Be In It.....
jugernot's Avatar
Okay, Well I'm trying to light the inspiration fire and motivated myself to get to work on Lemon Drop. So I finished installing by March Performance Serpentine Belt system. After three trips to Napa I found the proper belt size, which was a couple of inches less that what the instruction stated.
I also used a piece of 3/8 inch brake line to fad up a fuel line from the carb to the pump. I will be using a piece of stainless steel tube to replace it (more bling). I may have an issued with the routing of the lower radiator hose, but since I plan on using electric fans it may not be a problem.
I think I will work on the AC/Heater hoses next.. I can’t decide if I want to use steel braided to black. I know the steel braided would look great, but $$$ has been a little hard to find.
I have not inspired myself enough to finish the wiring thought.
Old 01-22-2009, 07:02 PM   #417
my67chevytruck
Under Construction
my67chevytruck's Avatar
looking good. keep chugging along.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 01-22-2009, 07:50 PM   #418
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I say use black hoses and paint the clamps a satin black..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 01-22-2009, 11:54 PM   #419
jugernot
Life, Be In It.....
jugernot's Avatar
I was thinking black hoses and polished clamps
Old 01-23-2009, 01:19 AM   #420
VA72C10
VA72C10
VA72C10's Avatar
It's come a long way.....can't wait to see it finished up and on the road...do you have a target date?
Old 01-23-2009, 02:31 PM   #421
jugernot
Life, Be In It.....
jugernot's Avatar
I'm shooting for my daughter's high school graduation...................She'll be 5 in March.
I would like to get the engine running by summer, this summer.
Old 01-28-2009, 12:52 AM   #422
jugernot
Life, Be In It.....
jugernot's Avatar
Okay, I spent about 2 hours trying to figure out what fittings I needed for the AC Heater lines. Then compared the priced with a braided hose and rubber hose. The braided kit would total $600. The rubber hose kit would total $350. This is using stainless fittings from www.gottoshow.com. So because of the cost I will probably go with the rubber hose.
Anyone know of a place to get a show stuff cheaper?
Old 01-28-2009, 02:35 AM   #423
hotrodhomi
hotrodhomi's Avatar
You might be able to get the hose made cheaper at the Parker fitting store in Sac. I think its called Sac. Hose and fittings. it right off the Causeway.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 01-28-2009, 09:05 PM   #424
jugernot
Life, Be In It.....
jugernot's Avatar
I did a quick search, but could not find anything about that business. Anyone got any info on this company?
Old 01-31-2009, 08:03 PM   #425
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Very slick build.
Mine isn't nearly as far along as yours, but I never thought of how much hoses were going to cost for the vintage air system on my truck.... add it to the list $$$
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
