Old 01-23-2009, 01:38 PM   #1
michael bustamante
michael bustamante's Avatar
1960 Guage cluster
Ok guys heres one for you, Im wiring my buddys 1960 3/4 ton with a new ez wiring kit, everythings going smooth so far but I think im going to run into a snag. Im at the point where I am trying to wire up the factory cluster and I was wonmdering if any of y`all would have a wiring diagram of the guage cluster, (ammeter,temp speedo and fuel guages)
Also I noticed theres light holes that say tandem axle and I think gear shift? did 3/4 tons share the same cluster as a dually/1 1/2 ton and just wired differently?
The wires that are throwing me mainly is the light that has the pink and dark blue coming for it. whats that for?
Ps: in case you need it, 383 stroker hei (gm) 3 wire alt, under 80 amps, electric fan, fuse box in factory location, relocated fuel cell, 78 chevy 3/4 ton 4x4 chasis swap with 6" susp and 3" body lift. Ill take pics and try to post.
1967custom
michael bustamante is offline   Reply With Quote
Old 01-23-2009, 03:01 PM   #2
4dranch
Shloooooong bed member #2
4dranch's Avatar
Re: 1960 Guage cluster
Hope this is what your looking for. link to 64 wire diagram
http://67-72chevytrucks.com/vboard/s...d.php?t=193429
David,
Daughters 66 truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=484601
Learning to drive a 3 on the tree:
http://www.youtube.com/watch?v=CcCMvRgBo1Q
4dranch is offline   Reply With Quote
Old 01-23-2009, 06:18 PM   #3
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
The "tandem lock", and "overspeed "lights could be found in almost all the clusters, my 65 1/2 ton has them, they are just not wired up, but you can faintly see them from residual light when the lights are on.
I do have 2 different types of the 60-63 standard cluster... one only has the provision for 1 blinker light, so I just wired up the right and left signal to it, its kind of cool, no matter whichway you go, there is only 1 indicator... the other standard cluster has 2 blinks, and the warning lights.
Do you have a standard cluster, or deluxe? they are different-deluxe has guages.
..0.. -standard
.'0'. -deluxe
Old 01-26-2009, 10:35 AM   #4
michael bustamante
thanks 4dranch that was what I needed! after along weekend I about got all the dash cluster figurred out thanks to the diagram.
conzcustom: This one actually has guages, an ammeter and a temp guage, and oil pressure guage. so because it has the temp guage and a dummy light for oil sender, where does the oil sender light go to? (dark blue and pink wires) oh yeah, only one turn signal indicator on this one too
1967custom
