#301 |
![]() Join Date: Oct 2007
Re: mylow53 build
lokar makes a pedal that should go in the stock location. i think it is the midnight series but dont hold me to that. i know lokar makes it though.
There is nothing you can't fix with a BFH or a FIRE WRENCH. 1997 chevy k1500 ext cab z71 (daily driver) sold 1996 chevy k1500 reg cab 4x4(daily driver)totaled 2008jeep patriot (wife's daily driver 2008 chevy 1500 ext cab 4x4 sold 2011 chevy 1500 crew cab ltz (daily driver) 1996 chevy 1500 reg cab 4x4 project sold 2006 pontiac grand prix gxp (daily work commuter) |
#302 |
Re: mylow53 build
thanks jimmy but that model uses a see saw fulcrum to pull the throttle cable i want the linkage to pass thru the original throttle hole then attach to the cable some how. that way i can reuse my original peddle... sounds crazy but why not i've come this far.
GT
Greg 1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school http://67-72chevytrucks.com/vboard/s...=215079&page=5 |
#303 |
Re: mylow53 build
sound cool not crazy. an your right you've come this far why not go the extra mile to have it what you want.
#304 |
Re: mylow53 build
Take some pics, as I am looking for the same arrangment!
#305 |
Re: mylow53 build
great looking truck, im usually on the 67-72 side of the board just stumbled onto this. subscribing for the ride!
#306 | |
Re: mylow53 build
As promised here's the update. i started the engine and let her run. and i couldn't see any oil pressure my pressure light was going out on start up but the gauge was reading zero. So I checked everything i could think of and still no pressure. sunday morning came and i pulled the distributer and measured the length, to see if it was engaging the pump. and every thing checked out. so using the drill i did a series of tests for pressure and eventually found a flaw in the wiring diagram on my new rebuilt gauges. simply put they miss labeled the ground and sender terminals. so put everything back together and pressure!!!!. ran the engine for 10 minutes and reved it and my heater hose explodes in the dash!. apparently when i tightened it, the hose clamp got hung up on some metal. I had to hose down the interior. glad i didn't have the carpet in!!!. slapped on the other front fender and too some picts! Hope it was worth the wait GT
Greg 1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school http://67-72chevytrucks.com/vboard/s...=215079&page=5 Last edited by mylow53; 01-26-2009 at 02:29 PM. |
#307 |
Re: mylow53 build
i took some picts of the underneith. there aint no space when it's down
#308 |
Re: mylow53 build
looking good, I can't wait to get to that point
1971 Corvette convertible 454@ 525 hp ![]() 1936 Chevy Truck street rod 1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up 1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html 1950 custom Chevy Truck |
#309 |
![]() Join Date: Mar 2007
Re: mylow53 build
Moral of the story. When you think that you have all of your bases covered something will come up to bite you.
The truck is looking great. I bet that you are getting excited. When you have a second in the garage, messure the width of your grill for me Keep up the good work. Marc |
#310 |
Certified Car Nut
Re: mylow53 build
#311 |
Re: mylow53 build
Man I need to see the hood on that thing. Ouccchh!!
Long live SLIM ------------------ At least try to buy American ![]() |
#312 |
Re: mylow53 build
Holy ****.
I need to run to the ****ter really fast. What a good looking truck. Bravo! -Ivan |
#313 |
Re: mylow53 build
Greg, looking very good. Glad to hear your oil pressure wasn't an issue. That could've been expensive. Are you going to make a maiden voyage anytime soon? Take some video,
Daniel u
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674 My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost 1960 (400/T350/?) Apache 10 short/fleet side-big window 1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4 2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB Doing my part to warm the globe ![]() |
#314 |
Re: mylow53 build
Man Greg that thing is looking Kick A$$.
Bernie |
#315 |
Re: mylow53 build
once the gass peddle is figured out and i have the seat it might move under it's own power. right now work is a lot of ot so it's hard to walk past this in the mornings. as one of my coworkers said at least i have work.
GT yes bernie my wife also cusses with dollar signs as well $$
Greg 1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school http://67-72chevytrucks.com/vboard/s...=215079&page=5 Last edited by mylow53; 01-27-2009 at 11:36 AM. |
#316 |
Re: mylow53 build
Greg--
It won't be long. Pretty soon you will have to update the Avatar. It seems like two different trucks. I went with a Lokar (nock off) type peddle. I got it off Ebay. It was under $75.00. You also have warm weather on your side. I was starring at 15 degrees this morning. Talk about taking your motivation away...... Good luck Marc |
#317 |
Re: mylow53 build
stopped my the upholstery shop and he has the bottom done still need to do the backs but i like!
#318 |
Re: mylow53 build
#319 |
Re: mylow53 build
a wise man told me not to total up the cost of the build. you really don't want to know.....
GT
#320 |
Certified Car Nut
Re: mylow53 build
Yeah I know what you mean. I had an excel spreadsheet for my build after a while I thought its just sick to spend this kind of money and my truck is still in pieces, so I stop looking at and kept spending.lol
#321 |
Re: mylow53 build
Looking real good. Memo to self, test run engine with fluids before carpeting...
#322 | |
Re: mylow53 build
It never begins out to be that much but it's sooooo easy to say, "yeah I could use that little thing here or that little thing there." I'm sure everyone that's in the same boat as you wanting to have a really nice 47-55 rig would die to know what you got in it so far. So that they can "better prepare themselves" for what's in store. I could guess close to $25k....but I might be way off. -Ivan |
#323 |
Re: mylow53 build
yes your a bit off, the paint was 15. and i know i got a great deal... there is no way to prepare or even budget for a dream truck. the only thing you can do, is to do at at the pace you can afford. i really don't want to think about what is in this, my wife on the other hand....
GT
Greg 1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school http://67-72chevytrucks.com/vboard/s...=215079&page=5 Last edited by mylow53; 01-27-2009 at 06:24 PM. |
#324 |
Re: mylow53 build
My justification has always been I got this in 1976 after selling 3 cars I really liked to pay for college, drove the wheels off of it, and now when I finish I will have a cooler new truck for cheaper than buying a new 4WD truck. Recent economy has kind of altered that argument financially but thats my story and I'm sticking to it. You can ALWAYS find something done for cheaper than you can build it, right now I could buy a 1965 Chevelle with a 5K motor, 2K rearend, 2K transmission, recent paint, rebuild disc brake front in, good interior, for 9K, its a 20K car easy. I can't even start to finish my 64 for twice that. My friend is out of work and needs to save his house. You also have to factor in the money you are saving on shrinks and a divorce because you are staying out of the bars.
#325 |
Re: mylow53 build
that a nice truck what color red is that looks good
