Old 01-24-2009, 12:10 PM   #1
olskoolchevy
olskoolchevy's Avatar
Question Which guages?
I'm getting ready to buy new aftermarket gauges(autometer probably phantom). How do I know whether to buy electrical or mechanical?
Thanks for any help yall can give me.
olskoolchevy is offline   Reply With Quote
Old 01-24-2009, 12:29 PM   #2
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: Which guages?
I'm looking to do the same thing. In my mind the electric ones would be easier
to install and you wont have to run an oil line into your cab.
Is that the only mechanical gauge?
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 01-24-2009, 01:21 PM   #3
olskoolchevy
Re: Which guages?
I think the speedo is offered elec. or mech. also. I'm not sure which other ones.
Old 01-24-2009, 01:24 PM   #4
clay68c10
clay68c10's Avatar
Re: Which guages?
I'd go with the electric speedo too, it's way more accurate and easy to recalibrate if you change gears.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 01-24-2009, 01:39 PM   #5
olskoolchevy
Re: Which guages?
Is there anything you have to have to convert to elec. speedo? Will it still run off of the same speedo cable?
Old 01-24-2009, 02:11 PM   #6
clay68c10
clay68c10's Avatar
Re: Which guages?
It should come with a sender you screw into the speedo cable threads on your tailshaft, then you just run the wires to the gauge. There's a button you push on the speedo head to calibrate it, I think they have you push it, drive one mile and push it again, and you're done.
No more bouncy needle when it's cold out or if you put too small of a bend routing the cable.
If you're running a later trans like a 4L60/80E with a built in speed sensor, you can just use that signal.
I'd like to see one of the gauge companies do an electric conversion of the stock speedo head...
13 Tahoe LTZ
Old 01-24-2009, 07:39 PM   #7
theyammieguy
accepting donations
theyammieguy's Avatar
Re: Which guages?
Oldskool, who did the body work on your truck?
1999 Yamaha roadstar 1600 chop. (in progress.)
See my builds here>http://s113.photobucket.com/albums/n238/nickrp_2006/
"Ya'll can go to hell, I'm going to Texas."
David Crockett
theyammieguy is offline   Reply With Quote
Old 01-24-2009, 07:52 PM   #8
olskoolchevy
Re: Which guages?
A guy in fort worth that i worked with when i lived there. Not a professional but he re-primered it in his shed for $250. Can't beat that. Other than that, the previous owner had the rest of the body work done in San Diego, CA. It's always been primered since I bought it in 2001.
