Old 01-24-2009, 01:49 PM   #1
70GMCer
70GMCer's Avatar
What bracket is this
Since this bracket came off a date coded 1977 350ci Chevy, & the PO told me the engine came from a Chevy truck, I thought I'd ask what it is.
It was attached to the one side of the engine block at the engine mounting holes.
Any ideas??
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 01-24-2009, 01:58 PM   #2
JW76
JW76's Avatar
Re: What bracket is this
The bracket goes between the engine block and the motor mount clam shell. There is supposed to be one for each side of the engine. The rod on the bracket connects to the two bolt holes on the cover over the torque converter bolted to bottom front of the transmission.
JW76 is offline   Reply With Quote
Old 01-24-2009, 02:09 PM   #3
70GMCer
70GMCer's Avatar
Is this for 2wd, 4wd or both?
thanks
1997 GMC Sierra Ext
1965 Mustang
Old 01-24-2009, 03:02 PM   #4
bigblock73
yeller
bigblock73's Avatar
I have never seen one of those on any 2wd I have owned (which is ALL I have owned).
bigblock73 is offline   Reply With Quote
Old 01-24-2009, 03:12 PM   #5
Dooley
Dooley's Avatar
I've had those support struts on several Turbo 400 equipped 4wds. The flywheel covers were cast aluminum.
Dooley is offline   Reply With Quote
Old 01-25-2009, 11:06 AM   #6
70GMCer
70GMCer's Avatar
So this is in fact for a 4wd truck, 73/87 models?
1997 GMC Sierra Ext
1965 Mustang
Old 01-25-2009, 03:58 PM   #7
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
Yes,only seen them on 4X4s
powerdriver 1958 is offline   Reply With Quote
Old 01-26-2009, 04:38 PM   #8
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Ditto, 4x4 only application.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 01-26-2009, 04:40 PM   #9
70GMCer
70GMCer's Avatar
thank you.....
1997 GMC Sierra Ext
1965 Mustang
Old 01-26-2009, 08:02 PM   #10
softballnrd27
Always a work in progress
softballnrd27's Avatar
Are they neccesary? I have them on both sides but I am going to 2wd, will I still need them?
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 01-26-2009, 08:08 PM   #11
mod58
Talking Re: What bracket is this
scrap pile!!!!!!!!!!!!!!!!!!!!!
mod58 is offline   Reply With Quote
Old 01-26-2009, 08:34 PM   #12
Albatrossian
Georgia Boy
Albatrossian's Avatar
You can use them for a torque strap..
81 GMC High Sierra, 2WD, 357ci/700R4, 3.73s, posi.
Albatrossian is offline   Reply With Quote
Old 01-27-2009, 06:44 PM   #13
Captkaos
Captkaos's Avatar
They aren't needed on a 4x2, you could sell them to a 4x4 owner, but most of them have probably scrapped them by now.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 01-27-2009, 07:37 PM   #14
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
I have the brackets on my untouched 78 2wd swb small block. It does not have the support rod, and I am not sure if it had the hole for it or not. When I disassembled the truck they did not go back on. I will look at them and see if the are the exact same or not. I am fairly certain, this truck had never had the engine out as it was a one owner whom I knew. Could be wrong though, wouldn't be the first time
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
