Old 01-24-2009, 06:46 PM   #1
LANDC
LANDC's Avatar
AC pump for Compressor?
I am sure there has been great discussion on this topic on these pages previously but I missed it. I have a 454 in my rig and want to install an on board air compressor to air down the meats. I know there are many options, but would like to get some feed back. Pros, cons, successes failures, generally what guys have done. I am not running ARB's, or air tools, I just need a good air source to refill my 44's after a day in the snow. I have been told certain pumps are bolt ons with the appropriate brackets and I am leaning that way. However I would like a fast fill so the more cfm the better. Thanks.
Custom Vehicle, Custom Problems.
LANDC is offline   Reply With Quote
Old 01-25-2009, 01:08 PM   #2
LANDC
LANDC's Avatar
Re: AC pump for Compressor?
Nobody?
Old 01-25-2009, 04:15 PM   #3
skchevota
skchevota's Avatar
I have heard of a lot of Guy using I believe the york compressors on the jeeps, i am not sure about the Chevy's. i have thought of doing this as well. I know some compressors you can just put a filter on the intake and others need a way to oil the incoming air because they don't have adequate oil in the case. I would do a search on google and see what turns up.
skchevota is offline   Reply With Quote
Old 01-25-2009, 04:21 PM   #4
bdydrp97s10
bdydrp97s10's Avatar
use a York or a sanden 508.. sanden 508 is better imo.. sanden is the same pump the Vintage Air uses and all those other A/C companies use. very easy to find brackets to mount it to a SBC or BBC..
check out alangrovecomponents.com for brackets.. and look on ebay for the pump.. i believe you can still pick up rebuilt units for about $150
My build thread--http://67-72chevytrucks.com/vboard/s...d.php?t=300333
bdydrp97s10 is offline   Reply With Quote
Old 01-26-2009, 03:44 PM   #5
Russell
Professional Grade
Russell's Avatar
Another option is a Harrison / Frigidaire A6 compressor. They are the big log compressors found in all GM vehicles from the late 60s through early 80s. They are self-oiled similar to a York, and put out a ton of volume at high pressures.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
