01-24-2009, 07:18 PM | #26 |
Re: Trailing Arm ?
even with the arms angled in the stock location you need a panhard or watts link...
also the factory arms have some "flex" designed into them, otherwise you would have little to no articulation, not that there is much anyway.... http://67-72chevytrucks.com/vboard/s...+trailing+arms
CHEVY ONLY Last edited by joe231; 01-24-2009 at 07:27 PM. |
01-24-2009, 11:43 PM | #27 | |
Re: Trailing Arm ?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-24-2009 at 11:45 PM. |
01-30-2009, 09:10 PM | #28 |
Re: Trailing Arm ?
Here's a few pics of the arms I've been modifying I still have one more thing left (which will add the character to the arm) and also the shock mount once I get them in the chassis. But this will give you an idea of what you can do with just a little clean up and thought.
www.bentcustomandperformance.com |
01-31-2009, 03:14 AM | #29 |
Re: Trailing Arm ?
I am looking at running a 15 by 10 rim with a 3.5 backspacing.the tire will be mt drag radial 325 50 15.Will it fit under the stock wheel well.
01-31-2009, 03:00 PM | #30 |
Re: Trailing Arm ?
It will be just about flush or extend just beyond the outer wheel well lip. So it will fit if you're not lowered. If lowered, more back-space will be required.
