Old 01-26-2009, 09:43 AM   #1
skeet85silverado
Starter Problem
I just put a used 350 in my truck this weekend. The problem i have is the motor runs fine when cruising but if i nail it from a stand still my starter makes a grinding noise on the flexplate. What is causing this problem.
skeet85silverado is offline   Reply With Quote
Old 01-26-2009, 10:06 AM   #2
James McClure
One shot, one kill.
Re: Starter Problem
Skeet, pull the starter and look at the bendix (clutch) try to move it with light force. If it moves replace the starter. If it is pertty tight starter probably needs to be shimmed. Make sure nothing on the starter is cracked\broken or loose. With the cost of a rebuilt at NAPA up here $18, just slam a new one in. The warantee is 3 years ta boot. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 01-26-2009, 12:50 PM   #3
dammitmitchell
the pollock
dammitmitchell's Avatar
Re: Starter Problem
agreeed
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 01-26-2009, 12:59 PM   #4
87c10slammer
truck addict
Re: Starter Problem
if a new strter or shims dont solve the problem then it may be your flex plate.. does the motor vibrate at higher rpms.. like more then a normal motor does?
trucks
87c10slammer is offline   Reply With Quote
Old 01-26-2009, 01:40 PM   #5
skeet85silverado
Re: Starter Problem
no it does vibrate.
Old 01-26-2009, 01:45 PM   #6
skeet85silverado
Re: Starter Problem
sorry i meant to say it doesnt vibrate
Old 01-26-2009, 08:02 PM   #7
Albatrossian
Georgia Boy
Albatrossian's Avatar
Re: Starter Problem
You said the starter is making noise when you floorboard it from a standing start? Does it grind when you're starting the truck?
81 GMC High Sierra, 2WD, 357ci/700R4, 3.73s, posi.
Albatrossian is offline   Reply With Quote
Old 01-27-2009, 10:57 AM   #8
skeet85silverado
Re: Starter Problem
When i start it. It starts right up. durning normal driving i have know problems but when i nail it. It sounds like the flexplate is hitting the starter.
Old 01-27-2009, 03:35 PM   #9
WRKTRUK
WRKTRUK's Avatar
Re: Starter Problem
Wanted to throw in my knowledge, but my dad has a 1992 F-150 and was doing the same thing, romp on the throttle and it sounded like the starter was engaging... well come to find out(after the lengthy time spent dropping the transmission) the fly wheel was bent off center almost a full 1/2 inch from one side to the other, bought a new one for $50 and it fixed the problem. Unfortunately I do NOT know why it happened, or what causes such a thing unless it just got REALLY hot, but haven't had a problem again in over 2000 miles. Just thought I would throw that at ya.
Ryan
WRKTRUK is offline   Reply With Quote
