Old 01-28-2009, 11:59 AM   #1
MrGoodpliers
MrGoodpliers's Avatar
Alternator bracket question
Will a '72 smallblock alt bracket fit '96 vortec heads? Also, I have a good power steering pump from a '68 el camino(sb), would it fit my '72 truck?
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC...
MrGoodpliers is offline   Reply With Quote
Old 02-01-2009, 07:05 PM   #2
MrGoodpliers
Re: Alternator bracket question
ttt
Old 02-01-2009, 08:45 PM   #3
piecesparts
Parts and more parts
piecesparts's Avatar
Look at the bolt pattern on the front of the heads. You may have to drill and thread a new hole, then again maybe not.
Old 02-01-2009, 10:24 PM   #4
100%Chevy
The pump should fit except:check that little steel nipple for the return line.It may not be pointed in the right direction to fit your application.
Mike.
100%Chevy is offline   Reply With Quote
Old 02-25-2009, 02:03 PM   #5
MrGoodpliers
NOBODY is running Vortecs? I have an engine on a stand up at my Dad's with Vortecs and I'm thinking about tossing it in the burb. I just wanted to know if there will be a problem with the bracket bolting up to the head.
Old 02-25-2009, 08:06 PM   #6
Sammy
As long as your heads are threaded. They are in the same spot as older engine V8's. Depending on what brackets. I used everything from a short W/P. May want to get a serpentine setup plenty in the junk yards with everything W/P pulleys, PS n Alt. Get the higher amp 1 wire system. Decent upgrade and simple.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 02-25-2009, 08:55 PM   #7
piecesparts
I have an engine in my garage, that has vortec heads on it, and the bolt holes look as if they line up with the heads on my older engines.
