1969 GMC 2500 V6 305L Question
I have a 1969 GMC 2500 with a V6 305L. Not really restored, it's in nice shape but I use it as a wood cutting truck. My questions:
1) It's a ***** to find parts because of the V6 305L. Every place I go insists (and I mean insists!) that I am mistaken, it must be a L6 because GMC didn't put V6s in 2500 until 19*** etc.,etc. Some conversations have gotten nasty. My engine is a rebuild because the first engine seized, but according the original bill of sale which I have, my vehicle came with a V6 305L. So what is the deal with this engine? Is it an odd-ball, special order, rare or what? 2) Can anyone recommend a place that stocks OEM replacement parts for this old of a vehicle? My local CarQuest/Napa/JCWhitney can't get me the parts. And a few other online stores I tried only sell high performance parts. I don't need a $300 distributor.... thanks in advance for any help.... |
Re: 1969 GMC 2500 V6 305L Question
Try this out great info here.http://www.6066gmcguy.org/
Have you tried summit racing?
Active Member
![]() Join Date: Jul 2007
Yep, it is an oddball...
I overhauled one back in the 70's and they definitely were strong engines. Built pretty solid. Only problem I recall was that if you ever got a fuel leak on the carb, the spark plugs were right on top to cause a fire. Unless you had a reason to keep it stock, I'd start planning on a replacement 350. Here's a forum that I looked at some time back that was talking about it. http://talk.classicparts.com/showthread.php?t=404 |
its all about the +6 inches
it's not an odd ball, it was common back then.
The 305 was the base engine in the CM/KM model trucks. If you tell them its a 66 model, then there computer should spit up the info they need. |
I have a radical idea!
I've never a had problem most anything for mine at a regular old Advance Auto Parts. It is in the computer, just make sure you get to the look it for a GMC and not a Chevy.
www.partsamerica.com is Advance's online website, and they have it listed as well. I bought a fuel for my dump truck a few months ago there.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
P.S., there are some things that the parts store can't get anymore, but there is usually plenty of NOS stuff for them on ebay.
#8 | |
as someone else suggested I did look up my 1969 vehicle on partsamerica.com and my engine does appears. However, the only distributors I can find are in the perforamce parts sections. I don't need a 300 distributor. So, I tried your suggestion on the partsamerica website and used a 1966 instead of a 1969. sure enough it pulls up a distributor that looks very much like the one I need. However, why a '66? Why not a '67 or 68? |
#9 | |
#10 | |
Active Member
It's an oddball "now" is what I meant... Sure there were a lot of them in some GMC trucks, buses and other work vehicles back in then but they're pretty scarce these days. A friend of mine and I went as far as Waco and Austin trying to find one some years back and couldn't find a single one. |
![]() Join Date: Feb 2004
Another suggestion is a local John Deer or Farm Implement store. The V-6 305 was a pretty beafy, torqued engine that many used for irigation pumps on the farm.
Keep yours original in my opinion. Odd ball equals cool.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
The deal on this engine is that it was designed in the late 50's when GMC's were known for building heavier duty engines than Chevrolet. GMC felt the mid50's GM V8's were not strong enough for heavy duty truck use and went with a heavy duty V6. Putting this engine(305) in a light duty pickup sounded good in 1960, but by the late 60's the market changed drastically,and was no longer practical. The larger versions 351, 401, and 478, were better suited in medium and heavy duty trucks.The V6 (351 and 478) were the first gas engines to be converted to diesel and had much better reputation than the 350 Olds. It is a unique piece of history,a time when a pickup truck had a truck engine.
#13 | |
![]() Join Date: Dec 2008
I would keep what is in it running as long as possible, If you use to work it is always cheaper to fix it than start changing engines. |
There used to be a lot of them around here in the 60's as the farmers loved them because they have a lot of touque for towing and they will lug down and idle across a field in compound low without a fuss.
Around here when they die they are replaced with V8's 95 percent of the time if the truck isn't scrapped. I don't know who you buy your parts from up there but usually NAPA or an independent is a better place to look for parts for something like this than NAPA takes care of a lot of the farm trade nation wide and is more apt to be able to source what you need. If the engine needs serious internal work I think I would take a serious look at swapping to a V8 of your choice and make things a lot easier in the long run. To be very honest the only reason I would keep the 305 V6 is if I was hellbent on keeping the truck 100% original and nothing else would do. |
#15 |
![]() Join Date: Aug 2005
The reason I bought my '67 was for the 351 V-6. They are great engines, lots of low end torque, they have a unique sound to them, and you will not find a tougher gas engine. Parts are out there, you just have to look for them. The 6066 GMC website is great, they know the sources and have the know-how to help you rebuild a GMC V-6 or keep one going. The original Stromberg carburetors are tough to find and even get kits for now, but most V-6 owners change to a Holley 2 bbl.. They do like gasoline (I am lucky to get 10 m.p.g.) but they have low compression and high quality exhaust valves, so 87 octane is fine and no additives are needed. The GMC V-6 was a lot more common than a lot of people think, it is just that the V-6 was primarily a commercial truck and school bus engine (that right there sould tell you something about them!). Find a parts store that has an old-timer. You think convincing some punk at Auto-Zone you have a 305 V-6 is tough, try asking for 351 parts. No, it's not a Cleveland or a Windsor......
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
#16 |
![]() Join Date: Mar 2002
Go on the 60-66 GMC page and check out the Buick V6 distributor conversion that I designed. Do not waste your money on a stock points distributor. The HEI is a great improvement. I would also second Bob's recommendation to use the Holley carb.
1968 GMC 305 V6 3/4 4x4 Stepside 06 Corvette Daily Driver Dallas TX |
#17 |
You can modify a Buick unit like Erl's, but you can buy them now also.
http://cgi.ebay.com/ebaymotors/HEI-C...mZ370088476646
#18 |
I've had good luck getting parts at NAPA, especially if the counter guy isn't afraid to open a parts book instead of relying on the computer.
Bob
V-6....only GMC Trucks have it! 62 GMC W5000 NAPCO-V6 65 GMC 2500 NAPCO Panel-V6 66 GMC 1000-V6 66 GMC 1500-V6 67 GMC K1500-SBC (originally a KM-V6) 68 GMC C1500-V6 68 GMC C1500-V6 68 GMC Suburban C2500 70 Chevy K20-SBC 71 Chevy C30 Longhorn-SBC 72 GMC Suburban C1500-BBC 72 Chevy C10-SBC 72 GMC C5500-ToroFlow Diesel |
#19 |
If your Toroflow runs, I would LOVE to see a video of it. I've never heard one and really want to!
#20 |
I didn't get a chance to try it out when I got it last fall. The place I got it from said that "It ran when we parked it." so I'll have to wait and see but I'm not holding my breath. At least there aren't any windows in the block. They do sound pretty cool when they're running!
Bob
#21 |
Thanks for the tip guys... I am in the process of trying to revive a 68 K1500 305 V6 4 speed truck that turns but doesnt get any fire.
I went to Napa on line and found most all the parts for the ignition system there I just looked up a 1966 model year. I will be replacing all the ignition system short of the Distributor itself as I am interested in the Buick evenfire swap after i get her home and operable... Call me strange but I like "oddball" things.I look at it as a challenge since it is all original (and rusty) the only really bad thing is the Cab, and I have located a nice solid 68 Chev. 2WD cab... the other thing is the farmer replaced the seat with some seats from what looks to be an 80's fullsize Olds.... when she is running im gonna start a new thread. ![]()
67/68 K/20 "The BEAST" 68 K15 V6 LWB. 73 K20 GMC Burb "The Bomber" 74 K/5 74 K20 Custom Deluxe 86 K10 Shorty 92 K2500 Burb 95 K2500 GMC Life is what you make it Live each day like it was your last Old GM Trucks never go out of style |
#22 | |
![]() Join Date: Jan 2001
The reason you'll find the parts more easily if you look for 66 GMC is because they were very common in the 66s (that's what I had) and by 60 were far less common. |
Tags |
gmc 2500 v6 305l |
