Old 01-31-2009, 05:24 PM   #1
THE AMERICAN GARAGE
THE AMERICAN GARAGE's Avatar
Grill question
HEY PEEPS! I AM FAIRLY NEW TO THE BOARDS AND HAVE A QUESTION ABOUT THE GRILL ON THE '53 GMC PICK-UP I BOUGHT BACK IN NOV.
PRETTY MUCH ALL OF THE TIME WHEN LOOKING AT '53 GMC GRILLS THEY ALL LOOK LIKE THIS:
ASIDE FROM THE FRAMED OUT AREA AROUND THE GRILL ITSELF HOLDING THE "GMC" TAG, ALL OF THE GRILLS I COMMONLY SEE HAVE VERT SIDE COLUMNS AND FOUR HORIZ BLADES.
NOW COMES MY QUESTION...BASED ON THE PICTURES OF MY OWN GRILL BELOW, WAS MY GRILL SOME KIND OF ODDBALL OPTION DONE IN CHROME?
YOU'LL NOTICE THAT IT IS ONLY 3 HORIZ BLADES ENCASED IN AND SET BACK FROM A PUSHED OUT FRAME WITHIN THE OUTER FRAME CARRYING THE NAMEPLATE. FOLLOW?
THANKS IN ADVANCE FOR ANY ANSWERS!
~DOC
THE AMERICAN GARAGE is offline   Reply With Quote
Old 01-31-2009, 08:31 PM   #2
54 jimmy
54 jimmy's Avatar
Re: Grill question
good question my 54 gmc was a 1 ton dually and has the 4 bar grill. i have seen the three bar before. i think it may have been a 53 year model thing. cause i only seem to see it on the 53 models ,but i could be wrong.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 02-01-2009, 01:42 AM   #3
OrrieG
OrrieG's Avatar
Re: Grill question
Maybe it is from a different series larger truck (1- ton, COE or ???). Just a thought.
Old 02-01-2009, 10:42 AM   #4
BIG CHEVY 3600
BIG CHEVY 3600 LONGBOX
BIG CHEVY 3600's Avatar
Re: Grill question
I can't tell the measurements but it looks like the bars are spaced wider apart on yours. Could be that a PO took one out and spread them out for some reason. The model year would be the best guess however. It should be easy to check that on forums like this. Just look for pictures of each year, that should explain all this.
If I were given 8 hours to chop down a large tree, I would spend the first 6 hours sharpening my ax.
Abraham Lincoln
http://s729.photobucket.com/albums/w...cpZZ3QQtppZZ20
BIG CHEVY 3600 is offline   Reply With Quote
Old 02-01-2009, 11:24 AM   #5
THE AMERICAN GARAGE
Re: Grill question
I DID NOTICE A 1948 GMC CHROME GRILL ON A 1950 3/4 TON TRUCK PICTURED ON PAGE 32 OF A S/C BOOK CALLED CLASSIC PICKUPS OF THE 1950s By Mike Mueller. I'M THINKING THAT THE CHROME GRILL, OBVIOUSLY AN OPTION STEP UP OVER A PAINTED GRILL WAS OFFERED IN A SOMEWHAT DIFFERENT VERSION THROUGHOUT THE 48-53 YEARS OR AT LEAST PART OF THAT TIME.
THANKS FOR YOUR ANSWERS AND OPINIONS!
Last edited by THE AMERICAN GARAGE; 02-01-2009 at 11:25 AM. Reason: WRONG PAGE NUMBER
Old 02-05-2009, 12:24 AM   #6
TheEstablishment
Re: Grill question
The grill you have is from the larger trucks, such as the 1 1/2 tons and the COE's. It looks like someone modified it to fit into your truck, which is why it sticks out so much. The 1/2 through 1 tons had grills like your first picture for the entire run of the body style. Some were chrome and some were painted.
TheEstablishment is offline   Reply With Quote
Old 02-05-2009, 01:55 PM   #7
1956cameo
1956cameo's Avatar
Re: Grill question
I bought a chrome three bar grille like you have in your truck at a swap meet, so I know it is factory. Like was said above me it is most likely from a larger truck and sometime over the years found it's way into your truck.
1956cameo is offline   Reply With Quote
Old 02-05-2009, 02:21 PM   #8
THE AMERICAN GARAGE
Re: Grill question
WHILE THESE SEEM LIKE REASONABLE ANSWERS, I ALWAYS THOUGHT THAT THE LARGER THE TRUCK, THE LARGER THE GRILL. I AM LEARNING THAT'S NOT THE CASE. I AM LEARNING ALOT FROM THIS SITE!
THANKS!
~DOC
Old 02-05-2009, 03:34 PM   #9
sgtusmc
sgtusmc's Avatar
Re: Grill question
Yep, just as stated above. My 53 has the 4 bars. the 3 bar grill is from the bigger trucks.
My build, 53 GMC / S10 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=305723
My build, 59 Chevy / 88 fullsize swap
http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc
U.S. Marines - Certified Counselors to the 72 Virgins Dating Club.
sgtusmc is offline   Reply With Quote
