02-01-2009, 03:17 AM | #176 |
PorterBuilt Man Crush
Re: 67-72 Bolt in pedal assembly
I say go with a set of fender well headers. I have a buddy that just did this on his 65, he has the Dropmember up front. I will try and post some pics here soon.
The 72 will live again |
02-01-2009, 06:29 AM | #177 |
>130dB Moderator
Hey, I saw you guys at the LA roadster show. I wanted to say hi and introduce myself but you guys looked busy.
Are you going to be up here in Sac next weekend?
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
02-01-2009, 12:36 PM | #178 |
Hey josh, does your truck sit on the frame or can you run the exhaust under neath where you have it now? I am talking about next to the transmission pan and the booster? Just an idea.
Josh
(Project truck) 1970 C10 under complete transformation My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
02-01-2009, 01:24 PM | #179 |
jlaird-
I really wish I knew why it doesn't seem to be working for you. When I spoke with Justin about this last he said we were waiting on some pictures from you. Either way, I'll gladly exchange it for an under dash unit, or if that doesn't suit you, feel free to return the whole assembly. I do agree that you can run it under the booster and trans in that location though. You had said earlier that the portion of your frame there doesn't lay out and it should not have to hang too low at all. Either way, give a call down if you would like to exchange or return that unit.
Jeff Savaglio Scott's Hotrods Oxnard CA 93030 |
02-01-2009, 01:33 PM | #180 |
If the application doesn't work as intended, or "fit" in this case, any reputable company would take it back or offer a solution that will work. That sounds just like what has been offered by Scott's Hot Rods...
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
02-01-2009, 01:34 PM | #181 | |
For some reason in that picture that Scotts posted, it looks like there is A LOT more room between the booster assembly and trans. But then again, that is a weld on unit on a modified frame, not exactly the same as what I have. I'll give you a guys a call this coming week. I'm not putting blame on anybody here and from talking to justin in the past, I know he will do everything he can to help. Thanks. Last edited by jlaird; 02-01-2009 at 01:38 PM. |
02-01-2009, 02:33 PM | #182 |
Whoops for some reason i missed that pic when you posted all those other pics. If you end up changing your mind about having the exhaust hang below the frame you can always wrap the exhaust with a heat shield wrap so you don't ruin any of you paint. Just an idea. I agree with Nate on that is pretty cool that scotts hod rods is willing to work with you. Another great company to do business with.
Josh
02-02-2009, 11:52 PM | #183 | |
myself.We will take care of you 100%. Justin |
03-24-2009, 03:26 PM | #184 |
VA72C10
Did this ever get figured out? I am thinking about ordering one of these for a blazer build and want to know if the issues have been resolved. Thanks!
Looking for a 67-72 swb or blazer project in or around VA. |
03-24-2009, 05:45 PM | #185 |
I exchanged it for an under dash assembly.
03-24-2009, 08:51 PM | #186 |
VA72C10
Thanks for the update...how is that working out and is there interference issues with factory or aftermarket A/C controls? Maybe jeff or scotts can chime in?
03-25-2009, 12:12 AM | #187 | |
pick-up running a hotrod air after market ac unit no issues with the install.We also installed a speciality wiper unit under the dash.The factory wiper motor was in the way. We have a customer that just called us and said he just installed the under the dash unit he said he had no issues with the factory ac.I asked him on the stock wiper he said he shaved the cowl smooth no wipers. Hopefully this helps you out on making your decision. justin www.scottshotrds.com |
03-25-2009, 12:21 AM | #188 | |
VA72C10
How much then for the underdash unit with the specialty wiper unit? Thanks!
03-25-2009, 12:29 AM | #189 | |
booster.Do you want the remote res to fill it up.Do you plan on filling it up from the under side of the dash. For the wiper motor kit do you want this with two speed control?One more last thing if you call us on wed we can give you discount on both items.If you are interested in our ifs we can do a package deal for you if you like. Justin www.scottshotrods.com |
