1967 Chevrolet K20 "The BEAST"
i had this started in the wrong location so here is the beginning
http://67-72chevytrucks.com/vboard/s...d.php?t=281437
67/68 K/20 "The BEAST" 68 K15 V6 LWB. 73 K20 GMC Burb "The Bomber" 74 K/5 74 K20 Custom Deluxe 86 K10 Shorty 92 K2500 Burb 95 K2500 GMC Life is what you make it Live each day like it was your last Old GM Trucks never go out of style |
Re: 1967 Chevrolet K20 "The BEAST"
I hope to get some work done today before the Stupor Bowl. its 40 degrees here ! it has not been above freezing in a month!
got some work done before the stupor bowl.... got the front cab support welded in.. and "massaged" a the door opening some on the passenger side... whoopeee!!
man its been COLD here again..grrrrrr
It was 40 and sunny out today...I took advantage and did some work today on the rear floor/ cab support area.. Slow progress... Im not an expert welder but im learning.. I just wish the wire feed was a little smoother. When its smooth I can actually weld pretty damn good
PICS... the last one is the frt cab support i did the otherday
before and during.... there is progess
Ttt
Man I thought I had some work to do. I too have a 67 K20 step and live in NY.I will be watching your build.
1967 K20 Stepside Longbed 250-6 sm420 |
Looks good! I wish I had the patience to fix a cab like that, Ive thrown them away in better shape when they were more work than just a bit of filler and block sanding!
thanks guys.. I look at it as a learning project.... I figure if i can make this thing look decent i can do anything..within reason... hey I figure its how you learn....the truck cost me 600 bux without a motor.... and it baiscally rot free up here thats a statement in itself...
I have done some work on the beast lately no pics as of yet... and scored a set of 10 in 16.5s with 36x12.50 Military OZs..the tread is kinda spent but will be good to get things in place and see how it all will fit...the truck originally had 35's on it so Im not afarid Ill have too many issues with clearance... more to come later
more work... the first few are from a couple weeks back... cutting and fitting lower a post.... and kick panel and a pic of the rear support....
Attached the kick panel, trimmed the rest of the rot out of the lower firewall. attached the lower A post.... it required some "tweaking" as the A post on this truck was hammered..... got it in and test fot the rocker... I think i may have to add some metal from the top of the A post patch i trimmed. as the rocker doesnt fit right on the lower post after i welded it in.... I am surprised how solid the cab front is once all the steel is in and welded in As I ahve said it IS a learning experience....
The "test fit" of the rocker and and one of the new / used 36's they look odd because the truck will be higher up once the big meats are mounted on truck
Had to tear myself away from my new K5 to go to harbor frieght and buy some flap wheel and found some other stuff i "needed" .. LOL
anyhow the day was nice n sunny so i got the K20 out to finish the bottom of the firewall cut a nice patch fit perfect only to find what i believed to be stainless was actually aluminum..... NICE NOT! grrr So I went to work getting some welds cleaned up and finished installing the rear cab support my welding skills are still not the best but they are improving
#15 |
Looks good to me yep
nickle and dime |
#16 |
NASA we have lift off.... worked on the rear corner today... got the B post in ahung a door and it actually fit pretty damn good considering how hammered the rear corenr was a year ago when i got this thing there is light at the end of the tunnel
it took some finessing with a BFH and choice swear words... and started to install After-crap corner.... i may have to make a relief cut in it when its all said and done... but I got it installed around the back curve and into the pinch area.. it got too dak and my camera only let me take 2 pics... tomorrows another day then i get to remove the door and try installing the rocker..... im sure the BFH will be needed some more ![]()
#17 |
They call me the Breeze...
![]() Join Date: Jul 2007
You are moving right along, nice job!!
Mike 69 K20 "Beer is proof God loves us and wants us to be happy"....Ben Franklin |
#18 |
completed the cab corner installation with one exception.... there is about a 1/4 inch gap between the back of the floor and the cab corner... not sure if it is because this cab was so toasted... or it is the ill fitment of aftermarket taiwanese re-pop junk from LMC
I had to make a couple relief cuts in the bottom just to get it to mate to the outer floor.... im wondering if i might have to cut the back with a pie cut..... the door now works almost perfect... I guess ill see what happens when i try the rocker tomorrow here is my work today... i had to make a relief cut in the badly tweaked area along the furthest right hand rib.. it closed OK I am not so worried about the appearance in the rear lower cab since i will have a box on it and no one will see it.... ![]()
#19 |
more progress....
#20 |
and finally the gap between the floor and the cab repair panel... any suggestions as to how to fix this would be appreciated....
the last couple are a Before and after of the damaged corner and a couple of my 292 note original appearing dark blue metallic paint on the blockk but the intake and valve cover have red on them..... will i have to paint this dark blue cause the only color close is FORD dark blue....
#21 |
SWB 4x4 Collector
![]() Join Date: Jun 2001
Looking good, I know it's a lot of work, but I am glad to see you were able to use that cab and not trash it. Good luck on the build. Trevor
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
#22 |
Are you using a flux core welder?
#23 |
thanks guys
yes its a flux core welder.... test fit the rocker today.... and re attached the back of the cab to the outerfloor using screws.... since i didnt like the gap at the bottom of the door I sliced the edge of the cab corner and re welded it.. after some persuasion with a BFH and a couple body hammers it fit pretty good and the door works well Not bad considering this is my first project... here are some pics
#24 |
now for the door gap reclaimation
#25 |
found this in a local bone yard to cap off the 292 when i install the 2 chamber Brake Booster never thought Id find one
