Old 03-06-2003, 09:35 PM   #1
Blackhawkdc
440 american Horses
Blackhawkdc's Avatar
Need a cam recommendation
I'm building a 496 stroker for my '69 1/2 ton. I'm sure some of you have seem my posts with other questions on this engine. But I'm looking for camshaft recommendations. I'd like to get 575 horse and 575 lb-ft of torque out of her. I'd prefer to stay hydraulic-flat tappet, but am willing to go to a solid lifter design. I'd love to convert to roller, but can't afford it. The engine will be about 10.2:1 compression, backed by a TH400 w/full manual valvebody, 12-bolt rear stuffed with either 3.73's or 3.55's, haven't decided yet. Any ideas out there?
Thanks.
Seth Petro
1969 Chev Short Step
425hp 350, TH400, big tires, fast truck
1979 Pontiac Trans Am
1991 Saturn SL1 - gas mileage! (and free)
1977 Buick LeSabre - for sale
May America bless God, and may God bless America
Blackhawkdc is offline   Reply With Quote
Old 03-06-2003, 10:38 PM   #2
72sbfs
I will assume that you plan on using some kind of aftermarket heads on this motor as it will help you reach the power level that you want. That being the case, the Edelbrock performer RPM packages are pretty hard to beat. They claim to get well over 500 hp with a 30 over 454 with 10:1 compression. It takes alot of guess work out of comming up with a good combination of parts.
Edelbrock's web site has a parts listing to build an engine to their hp levels. Including dyno printouts for these engines.
I have used their parts for engines that I have built in the past and have always had very good luck with them and no failures.
Just my opinion.
Hope this helps.
Sean
________________________________________
Size does matter, get a bb.
72sbfs is offline   Reply With Quote
Old 03-07-2003, 11:20 AM   #3
Mike C
Mike C's Avatar
Most of the cam manufacturers have a help line and is a much better source than a message board for an unusual combination. Call Comp, call Crane, call Isky. Get a recommendation from all of them, compare, and pick the one in the middle! Lots of trick grinds exist in their catalogs, or they can custom grind, compared to what is listed in the mail order guys catalogs, and prices aren't much different. In order to save a few bucks, you might be able to buy the cam manf. direct, then get other components (lifters, springs, pushrods) from your mail order vendor of choice.
My "guesstimate" is a cam in the 242 deg range at .050 on 108 LSA with .600 lift. Let me know what they recommend.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
