Old 02-02-2009, 10:31 PM   #26
LuckyHenriksen
LuckyHenriksen's Avatar
Re: Extra Gauge Mounting
Looks like a can opener was used. I was thinking about just making a metal plate to fit the hole, but I think it would just be cool and different to have the panel made out of the original heater control plate. I like the way it looks
It would be cool to figure out how to make the gauges angle toward the driver slightly........
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 02-02-2009, 10:49 PM   #27
texanidiot25
Eat My Rust
texanidiot25's Avatar
If you were to take the guages out of their cases, you could mount them in the stock bezel behind the lense, like I did my Cadi clock.
texanidiot25 is offline   Reply With Quote
Old 02-02-2009, 11:48 PM   #28
bigbadchev72
People know me
bigbadchev72's Avatar
I have almost the same setup in my blazer, If you take the 2 screws out that hold in the bottom of your heater controls, I mounted my bracket to that, I then bent the bracket so that it angles up a bit.
I mounted these ones in my 67' I will be buying a new bezel and gauges soon and will be mounting them behind giving it a factory look
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 02-03-2009, 12:23 AM   #29
pumpgas
pumpgas's Avatar
My set up is exactly like the factory one just didn't have the holes in the cluster already so I used a 2" hole saw and cut my own. That pic is very bad for seeing the gauges and was taken to show the new owner the steering wheel as it wasn't installed on the truck so she held it up and snapped.
00' Z28 ("wifes" car)
92' Mustang w/sbc everything needs a little heart beat
87' GMC Sierra Classic Short Bed Fleet side almost stock
69' Chevy short step carbed 6.0 w/400th trans. Completed w/325 miles on it
pumpgas is offline   Reply With Quote
Old 02-03-2009, 01:42 AM   #30
LuckyHenriksen
I like the stock bezel idea, but I don't want to cut the holes, I would probably mess something up. I think that with a little grinding and some TLC I can get two mounted in the control panel. I will update as I work on it. Now I have to see how small of autometer gauges I can get I heard they were discontinuing the 2 inchers?
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 02-03-2009, 02:07 AM   #31
Gray Ghost
Gray Ghost's Avatar
I have a couple of extras....send me your address and I'll ship you them to play with. I won't be using them as I am going to make mine out of wood.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 02-03-2009, 02:13 AM   #32
67ChevyRedneck
67ChevyRedneck's Avatar
It's not hard. Take you time, plan ahead, measure twice, cut once
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 02-03-2009, 02:38 AM   #33
LuckyHenriksen
Really? PM'ing
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 02-03-2009, 02:38 AM   #34
LuckyHenriksen
I have found that I need to measure 6 times
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 02-03-2009, 08:04 AM   #35
theyammieguy
accepting donations
theyammieguy's Avatar
I saw a radio the other day that works off an rf remote and allows you to mount the remote anywhere in the cab. I plan on buying this radio then welding a plate over the radio hole. Then I will cut holes for gauges, I will take some pipe and cut small spacers at an angle then mount the gauges
1999 Yamaha roadstar 1600 chop. (in progress.)
See my builds here>http://s113.photobucket.com/albums/n238/nickrp_2006/
"Ya'll can go to hell, I'm going to Texas."
David Crockett
theyammieguy is offline   Reply With Quote
Old 02-03-2009, 08:06 AM   #36
lax54650
when you do it take pics and post a how to so i can copy it. maybe i can find a dash locally
lax54650 is offline   Reply With Quote
Old 02-03-2009, 10:34 AM   #37
LuckyHenriksen
I thought about that...... the sony I just bought came with a remote
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 02-03-2009, 11:08 AM   #38
theyammieguy
accepting donations
Make sure the remote doesn't have to be pointed directly at the radio. The one I saw allowed you to mount the radio anywhere in the cab. I accidently said remote in the last post.
I thought about welding plates over the radio hole and heater control hole but weld them flush witg the rest of the dash so they're not recessed.
David Crockett
