Old 02-03-2009, 12:24 PM   #1
Burt4x4
Burt4x4's Avatar
SparkPlugs in a 4x4
Ok offroaders what plugs do you like and why?
I realize alot of plugs are very similar and most all will work fine.
I will be replacing all my plugs soon and thought I would get all the opinions out there
My engine: 1974 454 w/aftermarket EFI about 9:2 compression and Mallory ignition.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 02-03-2009, 02:34 PM   #2
snj8198
snj8198's Avatar
Re: SparkPlugs in a 4x4
what heads are you running?
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 02-03-2009, 02:35 PM   #3
Burt4x4
Burt4x4's Avatar
Shezz, I knew this was a boring post...
Ok so
NGK
Autolite
Bosh
Champion
AC Delco
Other?
Pick one!
Old 02-03-2009, 02:36 PM   #4
Burt4x4
Burt4x4's Avatar
336781 w/oversized valves
The vlaves are 2.19 & 1.88
The heads were shaved and the block decked. Even had the intake shaved to line up the ports perfectly.
What you think?
Old 02-03-2009, 03:01 PM   #5
snj8198
snj8198's Avatar
well?? im running autolite 24's in mine. also running Eddie's rpm oval ports and their 3551 system. plugs seem to be the right heat range with 9.4 compression and short duration cam. 218/226, 510/510, 112 lsa. -steve
Steve
Old 02-03-2009, 03:22 PM   #6
Burt4x4
Burt4x4's Avatar
Cool, sounds like your engine is very close to mine..
Not too sure what all the numbers meen but here they are:
Gross Valve Lift: I .505 & E .505
Duration @ .006 Tappet Lift I 254 E 262
Duration @ 0.05 I 210 E 218
Lobe Lift I .297 E .297
lobe Separation 111
CompCam 11-231-3
Ok so one vote for Autolite!
Next?
Old 02-03-2009, 03:23 PM   #7
Dooley
Dooley's Avatar
ACCEL 8178 and sometimes AC R44T.
Dooley is offline   Reply With Quote
Old 02-03-2009, 04:54 PM   #8
Burt4x4
Burt4x4's Avatar
Spark plugs are boring to talk about I guess hahahaaa
Old 02-03-2009, 06:13 PM   #9
68,69 K20
They call me the Breeze...
68,69 K20's Avatar
I run Accel, not sure of the part# offhand, 72 350.
Mike
69 K20
"Beer is proof God loves us and wants us to be happy"....Ben Franklin
68,69 K20 is offline   Reply With Quote
Old 02-03-2009, 09:56 PM   #10
Blue_71
Bloo
Blue_71's Avatar
this may offend some, so first off if it does im sorry, but from what ive seen and experienced for myself, i wouldn't put autolites in a lawn mower. they arent worth the metal they are made out of. i ONLY run AC Delcos. for your engine, i would say a R44TS, or because of the EFI i would recomend a CR43TS
NGK- good but overpriced
Bosch- okish, not highly recomended
champion- small lawn mower type engine only
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 02-04-2009, 03:33 AM   #11
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
I run only ngks or ac delcos. I am with him I have never heard anything good about autolites in my life just my .02 cents lol.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 02-04-2009, 10:30 AM   #12
Burt4x4
Burt4x4's Avatar
Cool!
Thanks for the opinions fellas
Anyone else?
Old 02-04-2009, 12:19 PM   #13
snj8198
snj8198's Avatar
crap...i new the autolite hits were on the way!
Steve
Old 02-04-2009, 01:21 PM   #14
RED72blazer
urban fourwheelin
RED72blazer's Avatar
NGK in all of my personal cars. And NGK in all of my customers cars unless they ask for something different or they aren't available.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
Old 02-04-2009, 02:36 PM   #15
Burt4x4
Burt4x4's Avatar
NGK is winning
Old 02-04-2009, 04:07 PM   #16
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
Went to the U.S.Nationals 2 years in a row and the most used plug in the sportsman classes was.......Autolite
powerdriver 1958 is offline   Reply With Quote
Old 02-04-2009, 07:23 PM   #17
snj8198
snj8198's Avatar
yeah, what he said.
Steve
Old 02-04-2009, 09:19 PM   #18
BurnoutNova
BurnoutNova's Avatar
I only use AC plugs in my old stuff. In fact, I use whatever is OEM. Be it a car im working on at work, my own stuff, a friends car I'm helping wrench on, ect... OEM. My Toyota truck I have NGK.
AC plugs are great, even for engines that have been modified. I use AC R45TS plugs in my Nova, and it has a completely aftermarket ignition setup (MSD box, Accel dist, ect) lots of people say theyre only good for bone stock applications.
One thing to say away from is those splitfire, or Bosch +2 or +4 plugs... waste of money eclectricity ALWAYS follows the path of least resistance.. meaning only one electrode will fire anyway, so 2 or 4 is pointless. Hope I didnt seem like I was rambling.
BurnoutNova is offline   Reply With Quote
Old 02-04-2009, 10:31 PM   #19
62 short step
62 short step's Avatar
I use ac delco.
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 02-04-2009, 11:14 PM   #20
71 super
71 super's Avatar
I really like autolites in motors with compression above stock,I also use them in my 92 softtail as well. With that said I have ac's in both stock motors in my 2wd and 4x4- ac seems to foul out quickly in higher compression engines.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 02-05-2009, 06:59 AM   #21
vtblazer
vtblazer's Avatar
Not a big block but I run ACDelco's in my TBI'd 383 and like em pretty well.
NGK's in all my toys though, snow machines, dirt bikes, 4wheelers etc.
vtblazer is offline   Reply With Quote
Old 02-05-2009, 10:09 AM   #22
Burt4x4
Burt4x4's Avatar
Cool!
Thanks for the comments fellas!
I'll prolly try the NGKs
I am running Bosh Platnum in there now, same plug I ran in my 350. Never had an issue with them just looking for a change I guess.
I'll be pulling the plugs to adjust my rockers so I figured I'll toss in some new plugs while I gotum out
Burt
Old 02-05-2009, 01:32 PM   #23
Burt4x4
Burt4x4's Avatar
Here it is! The best spark plug ever:
And they only want $25 bucks EACH
I was reading some reviews on a corevette site and most all think this is a scam, marketing ploy...
Too rich for me to "try"...
Old 02-06-2009, 07:16 AM   #24
dammitmitchell
the pollock
dammitmitchell's Avatar
i run accel shorties cause i refuse to hit my headers with a hammer..
with my luck a tire would somehow fall off..
but i like them.. it runs good and they havent burnt up even when i drive like a tard.. or when i drive like a little girl 9with kiddos in the truck)
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 02-10-2009, 10:13 AM   #25
383k5
I run Ac delco R45ts to be exact, thats in my 383, and 350
84383/465/208 D44/14b Detroits, 4 wheels discs, 8" front, 6" rear, 37" Irok Radials
96 ranger 4cylinder with the flowmaster. It's my race truck
64 C10...random pieces strew about.
383k5 is offline   Reply With Quote
