Old 02-04-2009, 04:18 PM   #1
lordhelmet
lordhelmet's Avatar
Rearend/Panhard Bar Questions
Hello All
I'm busy cleaning up my 69lwb from the cab back. Took off the bed, going to paint the frame... I order the Super track bar kit from ECE as well as their shock kit. My question is, with the new bar, do I need to maintain the old mounting spot on the rear end next to the pumpkin? I pretty sure I don't so how do I get it out? BFH? Is it just pressed in there? I've included a pic of what I'm talking about. Thanks for the help.
lordhelmet is offline   Reply With Quote
Old 02-04-2009, 04:34 PM   #2
see ten
WTB this ad
see ten's Avatar
Re: Rearend/Panhard Bar Questions
You will no longer need it. Yes...a BFH is your friend for this operation!
see ten is offline   Reply With Quote
Old 02-04-2009, 04:40 PM   #3
lordhelmet
lordhelmet's Avatar
Right on. I was givin it a few taps, but didn't want to open up on it until I knew if it was still needed or not.
Thanks!
Old 02-04-2009, 08:16 PM   #4
Andy4639
Old member
Andy4639's Avatar
I still need to get mine out as well. When your done with yours your welcome to come over to SC and do mine too!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-04-2009, 08:17 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Take the nut off, and then give it a good twist with a pipe wrench and it will come right out of there.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 02-04-2009, 08:29 PM   #6
lordhelmet
lordhelmet's Avatar
Good advice on the pipe wrench, and my east coast tour is next fall! I'll let you know how the removal goes, which for me usually means bloody knuckles. No blood usually means I haven't tried hard enough.
Old 02-04-2009, 08:46 PM   #7
Andy4639
Old member
Andy4639's Avatar
If you make it down to SC I will have a cold one waiting for you. Either here in Liberty SC in the upstate or at Garden City on the SC coast you can pick.
I have places in both.
I'm always looking for a reason to go down to the coast.
I need a bigger pipe wrench!
Old 02-04-2009, 10:32 PM   #8
bigguy69
dazed and confused
bigguy69's Avatar
x2
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
