Old 02-05-2009, 12:06 AM   #1
gcburdic
Restoration Virgin!
gcburdic's Avatar
Front shock issue
Hey guys,
Been noticing a small leak under my passenger side front A-arm, come to find out the shock is leaking at the shaft where it meets the cylinder....my question is, I got these through CPP but am not very happy about having to send it back to them (under warranty) so they can check it out and re-send me another one...
First, their customer service has been lacking...and second I'm not sure how long I'll be without one....
My solution is to buy a new front set (the current set are Doetsch Tech)...any board vendors/ member out there that can help me out....where is a good place to buy from that'll get'em to me quick??...should I just replace the fronts or should I replace the rears too??...should I go back with Doetsch Tech or KYB's??....
Thanks for any help....
FYI...front is lowered with 2.5" spindles only....
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 02-05-2009, 08:06 AM   #2
cdowns
cdowns's Avatar
Re: Front shock issue
local autoparts stores have shock asorbers// walk in walk out with shocks is the way i do it
Old 02-05-2009, 11:51 AM   #3
gcburdic
Restoration Virgin!
gcburdic's Avatar
cdowns....thanks....another question....When I called CPP, I was told that I should use stock height shocks....not the ones for lowered trucks??...Anybody got anything on that??....If not, I might just go buy some shocks from the local auto parts store....any particular brand names better than the other??
Geoff with a G
Old 02-05-2009, 12:08 PM   #4
cdowns
cdowns's Avatar
if you dropped your truck by spindles in the front nothing changed as far as shock measurements and stock works// monroe top of the line is good same with acdelco
Old 02-05-2009, 12:18 PM   #5
Andy4639
Old member
Andy4639's Avatar
I droped mine with springs in the front & back.
Now this is going to sound crazy but it's working for me.
I made a extension for the front shocks so I could use over the counter shocks. They have worked fine now for 3 years.
In the rear I used the same front shock, they are 3" shorter and are working fine as of now.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-06-2009, 03:32 PM   #6
Brad
Out of the carpool lane.
Brad's Avatar
I've got a 4/5 drop and have been using stock shocks for years without a problem, even with the bed fully loaded.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
