Old 02-05-2009, 11:28 PM   #1
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
How to? 2 tanks and 2 compressors?
How are you guys running 2 tanks and 2 compressors. That's what I want to do. Right now I just have airride installed on the front of my ride. I will be installing the rear real soon, and need to get another tank and compressor. I want to have the front on 1 tank and comp. and the rear on another tank and comp. Does that sound right? I assume that I will need to wire each comp. seperately, on it's own relay and pressure switch, correct? I didn't see a 2 comp. wiring setup on www.*****************
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 02-05-2009, 11:58 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: How to? 2 tanks and 2 compressors?
I would tie both tanks together and plumb both compressors to them. That way if one compressor quits,... the other compressor can still pump up all 4 bags.
(your way, will leave you stranded if one compressor goes out)
Keith
Convert to disc brakes.
Old 02-06-2009, 12:05 AM   #3
lolife99
lolife99's Avatar
Also look here:
http://www.air-zenith.com/download.asp.
Keith
Old 02-06-2009, 12:15 AM   #4
FnLow69
FnLow69's Avatar
ya i would tie them together also. yes you need a relay per compressor and if the tanks are tied together you could use one pressure switch and tie it to both relays
FnLow69 is offline   Reply With Quote
Old 02-06-2009, 03:58 PM   #5
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Yep, you're right, I never thought of that. KEwl. Thanks!!
