Old 02-07-2009, 03:29 AM   #1
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Tilt Steering!
Can someone tell me what steering collums will bolt up with little or no mods. I'm looking for tilt steering and dont have a clue as to what years will work. Or if theres another thread with this info. my truck is a 64. Thanks for the help!
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 02-07-2009, 12:10 PM   #2
Joey~AP
TexasBowhunter
Joey~AP's Avatar
Re: Tilt Steering!
I used one from a 77 Blazer. I also used the bracket from under the dash that has the brake pedal on it. It makes lining up the holes and linkage for power brakes easy!
Joey~AP is offline   Reply With Quote
Old 02-07-2009, 12:20 PM   #3
Chevy Fleetside
Chevy Fleetside's Avatar
Re: Tilt Steering!
73 to 80 van column. Not much mods need to be done. Maybe weld some nuts on column to bolt up to the bracket. You can get a collapsable lower column also. The column in the pics are from a 79 and it is a tilt. I have changed it out because the shifter was sloppy and now there is one from a 76 van camper in it.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 02-07-2009, 01:40 PM   #4
custom63
custom63's Avatar
Re: Tilt Steering!
Not trying to jump the thread but which year columns are the ones that will bolt over with light mods, has tilt and DOES NOT have a key in the column. I want to keep my key in the factory place of the dash.
custom63 is offline   Reply With Quote
Old 02-07-2009, 01:53 PM   #5
Woogeroo
Re: Tilt Steering!
tilt steering for our trucks, aftermarket or later model swap ins?
http://67-72chevytrucks.com/vboard/s...d.php?t=291299
Woogeroo is offline   Reply With Quote
Old 02-07-2009, 02:08 PM   #6
custom63
custom63's Avatar
Re: Tilt Steering!
Awesome link Woogeroo! That helps alot. Now I just have to find one.
Old 02-07-2009, 02:44 PM   #7
ruffrida2005
Re: Tilt Steering!
Thanks for yalls help, Anyone have some around East or Cen Texas tha I could get, tilt, floor shift
Paul
Old 02-07-2009, 10:16 PM   #8
Chevy Fleetside
Re: Tilt Steering!
The Van column. From 73 to 80.
Old 02-07-2009, 10:51 PM   #9
slepysal
slepysal's Avatar
Re: Tilt Steering!
were do you weld the nuts ?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 02-07-2009, 11:05 PM   #10
Strodder
Daring to be Different
Strodder's Avatar
Re: Tilt Steering!
I just bought a Camaro Tilt column. I'll be installing it in my 65. Look for it in my build thread. I chose the Camaro Column because I want a floor shifter.
http://67-72chevytrucks.com/vboard/s...d.php?t=327644
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 02-08-2009, 01:07 AM   #11
joe231
joe231's Avatar
Re: Tilt Steering!
where did you get your conversion knuckle? does your column have splines?
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 02-08-2009, 02:27 AM   #12
Captainfab
60-66 Nut
Re: Tilt Steering!
Another application for tilt columns that will work is in class A and B motor homes (Winnebago's) I've got one that came out of a '89 motor home and it is just like a regular van column.
Old 02-08-2009, 10:57 AM   #13
Chevy Fleetside
Re: Tilt Steering!
I pretty much install the column with the bracket under it, line up the column and mark where the bolt holes are on the column and just tack on a couple of nuts to the column and put it back in to make sure they are lined up right. After that you can pull the column back out and put a few more tach welds on the bolts so the stay put.
Old 02-08-2009, 10:59 AM   #14
Chevy Fleetside
Re: Tilt Steering!
Originally Posted by joe231 View Post
where did you get your conversion knuckle? does your column splines?
You can get them from Summit or a local speed shop. It is a combo 36 spline with a DD fitting on the other side. The picture shown without the front sheetmetal on, has a 73 to 87 lower truck shaft on it.
Old 02-08-2009, 11:16 AM   #15
joe231
joe231's Avatar
Re: Tilt Steering!
cool, thanks!!
do you know the diameter of the splined side? I see 5/8", 3/4", and 13/16"
i'm guessing both the splined and the DD are 3/4"?
CHEVY ONLY
Old 02-08-2009, 05:33 PM   #16
Chevy Fleetside
Re: Tilt Steering!
They are probably 3/4.
Old 02-08-2009, 09:36 PM   #17
joe231
joe231's Avatar
Re: Tilt Steering!
CHEVY ONLY
