02-07-2009, 04:52 AM | #1 |
are 73-90 a/c set up's the same.?
are the 1990 blazer a/c set up's, the same as the a/c set up's in the 1973 blazer.... and if not would any-body happen to know why....
02-10-2009, 03:23 PM | #2 |
Tonawanda 454
Re: are 73-90 a/c set up's the same.?
for the most part the A/C should be almost the same across the years... only the minor differences depending on engine and modifications done in the past. Looking at the A/C setup in my 76 truck with 350 was almost the same as my 91 burb with 454 (no rear air)...
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!! 04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011) In the past 30 years about 90% of Fords are still on the road, the other 10% made it home. ------------------- |
02-14-2009, 01:28 PM | #3 |
Superbad
Really? My 73 Suburban A/C pump is way different than the one on the 91 engine that will be going into my Suburban. I'll have to figure out how to hook up the A/C lines from the 91 A/C pump to the 73 Suburban once I get to that point.
02-14-2009, 10:16 PM | #4 |
thank''s for the input guy's.......... iam trying to install the compleate a/c set up out of a 90 blazer into a 73 blazer. like you said the pump's are diffrent. that's all i can see that look's diffrent aswell..........i'am going to try and use the suit case on the fire wall. the condencer, a/c pump, all ducking, heater and a/c control unit. if it's possible...........
