Old 02-09-2009, 11:09 AM   #1
1966-C20
Question Simple header question...
First of all, nice site. Some of you guys have rediculous trucks! Wow.
Here are the details:
1966 C-20 w/283 and 3 on tree and 78k orig. on the clock
Basically, it is all stock. My work truck.
My question is this:
Cracked manifold on left bank and looking to replace with something better/more permanent and LESS RUSTY. Don't want to spend the $$$500+ on name brand stainless headers so have any of you used these cheap ebay headers?
Particularly looking at these 2:
Huggers:
http://cgi.ebay.com/ebaymotors/SB-Ch...Q5fAccessories
And these:
http://cgi.ebay.com/ebaymotors/SBC-C...Q5fAccessories
Just speculating here, but, the huggers look like the least amount of re-work I'll need to do in order to mate up the existing exhaust work (straight back duals). But my concern w/ these is the motor mounts. Will I have to bang on the headers a bit w/ my ballpean to clear the mounts? Chopping up mounts is a no-go.
Let me know. Thanks guys.
1966-C20
1966-C20 is offline   Reply With Quote
Old 02-09-2009, 11:32 AM   #2
502tripower
502tripower's Avatar
Re: Simple header question...
I think you will have more problems using cheap headers than if you found another OEM exhust manifold...Those things are going to rust leak and be a nusance... JM2 cents...Good Luck
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
Old 02-09-2009, 01:54 PM   #3
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
headers have a fun nickname- hedaches
if you really do want some the block huggers would probably be the least amount of work.
while you are at it run a compression check on that side of the motor, a cracked manifold can sometimes cause a burnt valve
Old 02-10-2009, 01:32 AM   #4
Captainfab
60-66 Nut
Those first ones, I'm not sure they will clear the bellcrank, and the second set almost definitely won't.
If it were me, I'd just get a set of name brand steel headers. Hedman makes headers that fit this year of trucks and they are reasonably priced.....check summitracing.com. If you get a set of steel headers, and a couple cans of high temp header paint, strip off the factory paint and repaint, they will last a long time. The set on my '66 Suburban have been on there for 120,000 miles.....
