Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-09-2009, 02:24 PM   #1
djracer
djracer's Avatar
What do you think this ran
71 swb fleetside
Gm Goodwrench 350
Weiand Action plus
Speed demon 650 vacuum secondary
Comp cam xe262 .462/.469 262/270
hei distributor
5/8 hedders
2.25 exhaust
40 series flowmasters
Peg leg rear with unknown gear
275/60 radials all the way around.
Nothing removed from truck. I 'll give you guys a couple days of guessing before I post a times.
This was a 6cyl 3 speed truck what gear should it have?
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 02-09-2009, 02:36 PM   #2
joeys66pickup
Dr. Frankenstein
joeys66pickup's Avatar
Re: What do you think this ran
im guessing with the sixer the gear was Alittle Lower then usual?.....
Im guessing a 12.9xx
I Wanna Go Fast!!
joeys66pickup is offline   Reply With Quote
Old 02-09-2009, 03:11 PM   #3
PhilaTruck
Right on the line, baby!
PhilaTruck's Avatar
I think the rear gear is key to guessing how this stock set-up would perform, but I'll guess 15, based on a highway gear.
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly
Click and scroll down for site vendors!
Subscribe here!
PhilaTruck is offline   Reply With Quote
Old 02-09-2009, 03:54 PM   #4
71chevytruckguy
71chevytruckguy's Avatar
Im gonna say 9.8 @ 70 mph in the 1/8. Chris.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 02-09-2009, 04:01 PM   #5
Super73
Super73's Avatar
Still the manual 3speed?
If auto, how big of a stall?
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 02-09-2009, 04:28 PM   #6
djracer
djracer's Avatar
turbo 350 2000 stall
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 02-09-2009, 04:59 PM   #7
Super73
Super73's Avatar
60' --- 2.12
1/8 --- 8.82 @ 81.4
1/4 --- 13.76 @ 98.7
Old 02-09-2009, 05:14 PM   #8
Marv D
Registered Truck Offender
Marv D's Avatar
pretty tough with the limited info there Kevin,, but I'll bite
14.2's at around 85-90ish mph,,, guessing it had 3.73 gears from the era which seems was common with manuals and straight 6's,, but if it was one of the hwy gear trucks (3.0x gears,,, closer to 14.9's or more would be my guess.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 02-09-2009, 06:04 PM   #9
Wild83C10
Wild83C10's Avatar
Well I'm guessing it must have run pretty good if you are posting. My truck had a similar setup but with 3.42 instead of the original 2.73 and it ran mid-14s. So I would guess 13.9 @ 98.
My truck was an oringinal 6 cyl, 4 speed and it had the 2.73 rear gears.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 02-09-2009, 06:25 PM   #10
joeys66pickup
Dr. Frankenstein
am i the only one with faith in the peg legger(ok i was generous but whatever)
is the action plus a dual plane intake? and is the xe262 a flat tappet or roller?
I want to see pictures of said truck
I Wanna Go Fast!!
Old 02-09-2009, 08:12 PM   #11
djracer
djracer's Avatar
dualplane and hyd cam
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 02-09-2009, 08:52 PM   #12
383 Stroker
383 Stroker's Avatar
Mid 15's 1/4... High 9's 1/8...
Video's of my Truck Racing
1967 C-10, 383ci Sbc, TH350, 3200 stall, 3.73 gear
383 Stroker is offline   Reply With Quote
Old 02-09-2009, 10:33 PM   #13
Pyrotechnic
Pyrotechnic's Avatar
14.7
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 02-10-2009, 12:04 AM   #14
hotrod 80
mini truck racer
hotrod 80's Avatar
With a correct peg leg dual burn out and air pressure adjustments . 13.95 @ a tad under 100 .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 02-10-2009, 12:12 AM   #15
nxtruck
nxtruck's Avatar
I'll say around 9.00-9.10 @ 80 and 14.00 @ around 92 or so.
As far as the gear is concerned, I was under the assumption that most of the 6-cyl/ 3spd manual trucks came with 3.73s.
Chris
1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas
7.02 @ 95.8, 1.45 60'
1965 Chevy C10 LWB, 355 sbc, TH350, daily driver
nxtruck is offline   Reply With Quote
Old 02-10-2009, 12:25 PM   #16
LuckyHenriksen
LuckyHenriksen's Avatar
So when do we get to know the time
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 02-10-2009, 01:50 PM   #17
djracer
djracer's Avatar
after you quess! He ran it sunday. here's a pic.
I think some of you are forgetting these pigs weigh about 4000 pounds.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 02-10-2009, 02:29 PM   #18
LuckyHenriksen
I guess 15 flat in the 1/4
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 02-10-2009, 02:54 PM   #19
djracer
djracer's Avatar
We think the truck has a 3.42 gear but not sure. It turns about 2700 at 70 mph with the 28 inch tire.
Best 1/4 ET @ mph: 14.74@91.55
Best 1/8 ET @ mph: 9.46@75.02
Best 60 ft: 2.202 on Radials
Engine: 350
Transmission: TH-350
we are planning on doing a 383 with fast burn heads and a posi of course.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 02-10-2009, 03:05 PM   #20
meansting04
meansting04's Avatar
i gonna say 13.80 @ 80 ish.
67 gmc 1/2 ton, 5.0 v6, 4 speed SOLD!!
70 Chevy C-10, 355, th400, 3.73's 2/4 drop
meansting04 is offline   Reply With Quote
Old 02-10-2009, 04:30 PM   #21
Pyrotechnic
Sounds more like the famous 3.08. That's about what my truck does with the same gears and tires.
Old 02-10-2009, 05:00 PM   #22
Ont67shortbox
15.55-15.65 at 72-74 mph
Ont67shortbox is offline   Reply With Quote
Old 02-10-2009, 05:53 PM   #23
djracer
djracer's Avatar
I posted the times in my last post.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 02-10-2009, 07:03 PM   #24
Marv D
Marv D's Avatar
Originally Posted by Pyrotechnic View Post
14.7
WAY TO Go Dude!!!!! Nothng like NAILING it from the hip!
Old 02-10-2009, 08:29 PM   #25
jgreene0717
Jason
jgreene0717's Avatar
I am the owner of said truck. When I got home this afternoon, I checked
the ratio 43 tooth ring gear and 14 tooth pinion gear so it is a 3.08. What do you guys think it will do with a posi and 3.73 rear gear?
jgreene0717 is offline   Reply With Quote
