Old 02-08-2009, 03:27 PM   #1
hotrodhomi
hotrodhomi's Avatar
Anyone install their trim with tape?
Anyone install their trim with tape? Almost all new cars have the trim taped on, is there any reason that it shouldn’t be done to our trucks?
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 02-08-2009, 03:52 PM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Anyone install their trim with tape?
well....
taped on huh
thats a first...
by golly imona camerflauge tape my triummm bak on scooter!
John
1999 Toyota Tacoma 4x4
Old 02-08-2009, 03:58 PM   #3
truckintexas
I bought lower woodgrain trim from GM in 1990. In some areas, they provided clips with a 3M adhesive backing. I never could get them to adhere well, and I wound up using the standard "all metal" clips. Of course that was 1990. I'm sure adhesive products have improved since then.
truckintexas is offline   Reply With Quote
Old 02-08-2009, 04:05 PM   #4
FlartBastinSr
As I recall some of mine were a mixture of the tape and metal fasteners. To be honest the tape seemed secure enough but I didn't like how far it stood off the body surface.
FlartBastinSr is offline   Reply With Quote
Old 02-08-2009, 11:36 PM   #5
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Did my Blazer's trim with 3M's tape.
Still holding strong 5 years later.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 02-09-2009, 08:34 AM   #6
1970cstblazer
1970cstblazer's Avatar
Thumbs up Re: Anyone install their trim with tape?
I reuse the original plastic GM clips, and buy the adhesive tape by the roll from 3M.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
2017 Sierra 1500 SLT 4WD, Black, 46k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 67k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 02-09-2009, 12:53 PM   #7
Curbstone Mech
Active Member
I've used the 3m tape in the past and its held up fine on a truck I keep garaged.I'm going to use it on my GMC that stays out as soon as I get my stripes painted on the sides, then apply the 3m tape. I don't want to drill holes in a truck that never had them and sits out in the weather to rust..
We'll see how it goes.
68 short fleet
383 stroker, 700r4 373:1 posi
72 GMC 3/4 ton- weekly driver
700r4 351;1 posi
Curbstone Mech is offline   Reply With Quote
Old 02-09-2009, 01:15 PM   #8
project1971
project1971's Avatar
there is a differance in 3m tape. its defined by the color and i think the gray is what you want for this application
2008 Ford FX2 Screw
1971 C10 project in shop now!
2004 Pontiac Grandam (wifes)
2000 Cavalier z24 (gas saver)
project1971 is offline   Reply With Quote
Old 02-09-2009, 01:21 PM   #9
Curbstone Mech
Active Member
Good to know.
I think what I used a few years ago was red, but maybe the part that peeled off was red. In any case I'll be buying new stuff and I'll check on that color you mentioned-don't need my trim falling off during the first rain storm.
68 short fleet
700r4 351;1 posi
Old 02-09-2009, 01:52 PM   #10
Shock_Me
Shock_Me's Avatar
I've used the 3m tape on occasion, and I've found that if you wipe the area with some rubbing alcohol prior to applying the tape, you'll get a good strong bond.
Pete
Shock_Me is offline   Reply With Quote
Old 02-09-2009, 01:58 PM   #11
c10crazy
Like a Rock!
c10crazy's Avatar
The tape Bobbyk posted is the good stuff.
69 LWB
Runs great - work in progress
Mess with me and you mess with the whole trailer park!
c10crazy is offline   Reply With Quote
Old 02-09-2009, 03:42 PM   #12
liftmeup
Why not just use the clips ? They held the trim on for 30 yrs...+ you Can remove them without bending the trim up and having to clean all the residue from the tape off if you ever repaint or repair any parts.
liftmeup is offline   Reply With Quote
Old 02-09-2009, 04:08 PM   #13
hotrodhomi
hotrodhomi's Avatar
I not sure I want to drill holes
'66 impala ht
Old 02-09-2009, 04:10 PM   #14
tim21391
tim21391's Avatar
i used 3m tape on my trim for my lower of my bed..held strong with no problems
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 02-09-2009, 04:31 PM   #15
charlie diaz
charlie diaz's Avatar
the factory used tape to apply trim on my 87. Most of the trim is still on there. All of it would be on if it hadn't been caught on tree limbs and such. the only thing is that it creates a place for water to sit and rust the metal. on the places where the trim has come off on my truck, you can still see the adhesive and pitting where the water sat. but the same could be said about the holes and clips. my metal cab trim below the back window on my 69 caused areas to rust, so it's a toss up. the tape should hold excellently though. Trim is just an accent, so who cares how it's applied? It's not like you're trying to use bondo to make a fender.
charlie diaz is offline   Reply With Quote
Old 02-09-2009, 04:33 PM   #16
charlie diaz
One other point, what if you end up changing your mind about the trim at a later date? Adhesive will be a lot easier to clean off than holes will be to weld up. Just a thought.
Old 02-09-2009, 05:00 PM   #17
allforfun
BobbyK, can you tell me what the ID is on that 3M tape? I work for a wholesale distribution company. We buy directly from 3M almost every week and I wanted to see if its something I could get a sample of to experiment with.
allforfun is offline   Reply With Quote
Old 02-09-2009, 06:03 PM   #18
hotrodhomi
hotrodhomi's Avatar
That's why I'm asking
'66 impala ht
Old 02-09-2009, 06:23 PM   #19
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
My trim was already fitted with a combo of the original metal clips and the tape, and when I needed to replace my damaged trim the replacement trim came with new adhesive strips and they have not held as well as the stuff I had to remove. And as has already been mentioned the adhesive pads held the trim to far off the body for my liking. I'd say the tape would be fine if you don't want holes in the body where there were none to begin with but it would be real important to get the best available tape out there, imagine the wind getting behind it on the freeway and tearing it off....what about heavy duty Velcro?
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 02-09-2009, 07:19 PM   #20
BobbyK
BobbyK's Avatar
My Dad worked for 3M and he got that large roll at the Company store extremely cheap.
It came in a plastic bag with no product numbers on it.
I do know they sell it in 5' rolls in the parts stores for around $8.00 bucks.
Old 02-09-2009, 09:22 PM   #21
BurnoutNova
BurnoutNova's Avatar
Originally Posted by oldblue1968chevy View Post
well....
taped on huh
thats a first...
Thats actually how most everything is helf on now, since the mid 80's manufacturers have been using double sided tape to attatch molding, trim and emblems.
BurnoutNova is offline   Reply With Quote
