Old 02-11-2009, 12:51 AM   #1
otef546
Junior Member
master cylinder 71 72 disc question
I went to autozone to get a new master cylinder and they asked all the normal computer questions except if the truck had manual or power brakes.When I questioned him about this he said there was only one part number for all 1/2 ton 71 and 72 and that it didn't matter if it was manual or power.When I look in all the catalogs like LMC , etc they all show two different numbers so what is the deal and who is correct?
thanks Mike
otef546 is offline   Reply With Quote
Old 02-11-2009, 09:04 AM   #2
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: master cylinder 71 72 disc question
NAPA lists the same master cylinder for both manual and power for both 1971 and 1972 1/2 tons.
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels
1970cstblazer is online now   Reply With Quote
Old 02-11-2009, 09:42 AM   #3
chris71
chris71's Avatar
there is only one, the power booster is only an assist to the braking system that already exist in the truck, power and non power MC's are the same
now, there is a difference between disc/drum, drum/drum, and disc/disc master cylinders because disc brakes require a higher volume of fluid to work, therefore the resivoirs are bigger
'55 3100 2nd series short-bed stepside
'70 Corvette coupe stingray
'71 Chevelle 2-dr coupe SS clone
'71 C10 long-bed fleetside
'83 long-haired brunette wife
chris71 is offline   Reply With Quote
Old 02-12-2009, 01:53 AM   #4
badpeanut
Not a bad nut after all..
badpeanut's Avatar
I went to buy a master cylinder for my '72 1/2-ton 4x4 recently and they couldn't decide if it should be a 1-1/8" bore or 1-1/4" bore. Is 1-1/8" bore for 1/2-ton trucks and 1-1/4" bore for 3/4-ton trucks?
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 02-12-2009, 03:18 AM   #5
otef546
Junior Member
thanks for the answers
Mike
Old 02-12-2009, 12:26 PM   #6
Andy4639
Old member
Andy4639's Avatar
71 72 trucks should use the same master cyclinder for the right truck.
Chevy truck chassis service manual series 10-30.
Section 5-2:
C,K,P 10 series has manual master cyclinder non booster mounted to fire wall.
C,K,P-20 thru 30 series same as above with vacuum assist booster.
C-30 with H-22 option which shows lines going to the frame booster
P-30 with H-22 Option
This is straight out of the manual.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
