Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-11-2009, 10:24 AM   #1
drag_72
Ready to go fast!!
drag_72's Avatar
What kinda numbers???
all my motor specs are in my sig. what kinda 1/4 numbers you think it will be puttin down with good suspension?
454 block .30 forged aluminum pistons
steel crank
valve job
Holley Strip Dominator intake
1030cfm holley carb, 250 plate shot
roller rockers Erson Solid cam split duration 307/310.
.575/.595 lift
milodon oil pan
fab. aluminum valve covers
4 bolt main splayed anodized caps
all studded
drag_72 is offline   Reply With Quote
Old 02-11-2009, 12:36 PM   #2
Marv D
Registered Truck Offender
Marv D's Avatar
Re: What kinda numbers???
yeeeesh, we just went through this in another thread. Your gonna have to get a whole bunch more specific if you want anything +/- 5 seconds
weight?
short bed / long bed?
chassis mods?
slicks?
gears?
Trans?
convertor?
more specific info on heads (casting # or flow #'s)?
conpression?
exhaust?
... that would be a good start
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 02-11-2009, 02:49 PM   #3
drag_72
Ready to go fast!!
drag_72's Avatar
oh sorry must of not seen it sorry! i will try to get all that i can!
steel crank
valve job
.575/.595 lift
milodon oil pan
all studded
Old 02-11-2009, 03:04 PM   #4
drag_72
Ready to go fast!!
drag_72's Avatar
4,000..just a guess
short bed
trailing arms, coil overs
29.50 x 12.00 slicks
3.73 gears
built 350 turbo
3500 stall
3964292 not sure on the flow #'s but i will get them
10:1 compression
hooker comps. 1-5/8" x 27" Primary Tubes into 3 in. exhaust into Dynomax Ultra-Flo Welded Mufflers
if this is enough to get some what close take a shot but if more is needed i will do my best lol i just need a little somthing to get me going to get that muther done! lol
steel crank
valve job
.575/.595 lift
milodon oil pan
all studded
Old 02-15-2009, 06:32 PM   #5
drag_72
Ready to go fast!!
drag_72's Avatar
anyone?
steel crank
valve job
.575/.595 lift
milodon oil pan
all studded
Old 02-15-2009, 07:08 PM   #6
djracer
djracer's Avatar
I'll quess. High 11 to low 12's
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 02-15-2009, 09:32 PM   #7
ProStreet68SB
The Engine Whisperer
ProStreet68SB's Avatar
I'm gonna guess pretty high 12s
ProStreet68SB is offline   Reply With Quote
Old 02-15-2009, 10:50 PM   #8
joeys66pickup
Dr. Frankenstein
joeys66pickup's Avatar
you could run a 14.xx If you forgot that a warm up burnout is supposed to "heat" the tires not shred them to the cores and then slip an slide the whole track
I Wanna Go Fast!!
joeys66pickup is offline   Reply With Quote
Old 02-15-2009, 10:54 PM   #9
nxtruck
nxtruck's Avatar
I would guess somewhere in the low 8s in the 1/8 and low-to-mid 12s in the 1/4. These guesses are motor-only passes.
Chris
1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas
7.02 @ 95.8, 1.45 60'
1965 Chevy C10 LWB, 355 sbc, TH350, daily driver
nxtruck is offline   Reply With Quote
Old 02-15-2009, 11:43 PM   #10
Marv D
Marv D's Avatar
I have no experience with BBC trucks, but I'd have to say mid-high12's if all goes well and you shift at the sweet spot to torque your way to the stripe. But... just a guess from what I've seen other well built, heavy 454 trucks do at the track. Optimized tune and driving,,, maybe even slip into the 11's in good air. Keep in mind every 2000 feet above sea level will cost you roughly .2 seconds in 1/4 mile ET. Good air / bad air at your elevation will help or hurt your ET too.
Old 02-16-2009, 01:16 AM   #11
hotrod 80
mini truck racer
hotrod 80's Avatar
spraying outta the hole 11.88.
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 02-16-2009, 01:53 AM   #12
LuckyHenriksen
LuckyHenriksen's Avatar
Has anything been removed to reduce weight?
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 02-16-2009, 09:04 AM   #13
djracer
djracer's Avatar
not much he said 4000 pounds!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 02-16-2009, 06:44 PM   #14
Super73
Super73's Avatar
Hard to say. I've seen a stock headed big cam 454 with headers and intake run a low 14's on the motor and with 180hp jets go mid 12's as I drove around him about the 330' mark. He did light me though...
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 02-16-2009, 09:12 PM   #15
djracer
djracer's Avatar
what heads are on your motor and how much compression?
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 02-16-2009, 09:38 PM   #16
drag_72
Ready to go fast!!
drag_72's Avatar
i would be happy with high 11's low 12's! thats actually what i was shooting for! but i just got stock heads but they have been worked over. its got 2.19 1.88 vavles and some porting, i got 10.5:1 compression and not a whole lot of weight reduction yet! i have little stuff like no inner finders, fuel cell to back, battery to back, but i would like to do like a glass hood or somthing in the long run but try to keep it all steel? i guess thats just my style lol thanks for all the replies!
steel crank
valve job
.575/.595 lift
milodon oil pan
all studded
Old 02-16-2009, 09:51 PM   #17
djracer
djracer's Avatar
come up with a casting number on the heads that could make a huge difference
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 02-16-2009, 09:54 PM   #18
drag_72
Ready to go fast!!
drag_72's Avatar
okay are they on the back of the head?
steel crank
valve job
.575/.595 lift
milodon oil pan
all studded
Old 02-17-2009, 08:26 AM   #19
djracer
djracer's Avatar
they should be under the valve cover
Do you know what the 454 came out of?
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 02-17-2009, 03:45 PM   #20
drag_72
Ready to go fast!!
drag_72's Avatar
oh yah i know where they are now! not really sure what it came out of? we have alot of big blocks around.
steel crank
valve job
.575/.595 lift
milodon oil pan
all studded
Old 02-17-2009, 04:26 PM   #21
joeys66pickup
Dr. Frankenstein
my stock ones SUCK(2.06 intake like 1.8x or something exhaust)they would flow good if they were for a small block
I Wanna Go Fast!!
Old 02-17-2009, 04:28 PM   #22
drag_72
Ready to go fast!!
drag_72's Avatar
i got 2.19 intake 1.88 exhaust though lol and they are ported
steel crank
valve job
.575/.595 lift
milodon oil pan
all studded
Old 02-17-2009, 05:08 PM   #23
71Dragtruck
71Dragtruck's Avatar
I'll guess low 13's to high 12's on motor. Let us know when you get it out and make some runs.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 02-17-2009, 05:42 PM   #24
joeys66pickup
Dr. Frankenstein
see so it has to be atleast faster then mine! but i only weigh in at 3400ish now
I Wanna Go Fast!!
Old 02-17-2009, 08:15 PM   #25
drag_72
Ready to go fast!!
drag_72's Avatar
hell yah i will for sure let you know! track has already opened up so i should have a turn key truck in the next few weeks? and ya i wish i could lose some weight lol is that weight with you in it?
steel crank
valve job
.575/.595 lift
milodon oil pan
all studded
