Old 02-11-2009, 10:07 PM   #1
MyMach5
MyMach5's Avatar
Newb Mistake...Took Plug Wires Off Without Marking...Help Please!
So I got all excited last night putting my new valve covers on and took the plug wires off the drivers side of the engine with out marking them first. I have an MSD StreetFire Distributor and for the life of me can't figure out which post is #1. Any help would be awesome.
Thanks.
MyMach5 is offline   Reply With Quote
Old 02-11-2009, 10:18 PM   #2
pumpgas
pumpgas's Avatar
Re: Newb Mistake...Took Plug Wires Off Without Marking...Help Please!
Thanks.
Ok here goes
Start just to the right of center should be #1 then it goes clock wise from there 1 8 4 3 6 5 7 2 and as for the engine evens on the pass side starting with #2 and odds on the drivers side starting with #1.
00' Z28 ("wifes" car)
92' Mustang w/sbc everything needs a little heart beat
87' GMC Sierra Classic Short Bed Fleet side almost stock
69' Chevy short step carbed 6.0 w/400th trans. Completed w/325 miles on it
pumpgas is offline   Reply With Quote
Old 02-11-2009, 10:24 PM   #3
Cunit69
Take off your dist. cap and pull the # 1 plug and get it up with compression. Mark your dist. and put the cap back on. Then put # 1 where the mark is and continue clockwise 8436572. Then that should be it.
Cunit69 is offline   Reply With Quote
Old 02-11-2009, 11:20 PM   #4
Green Machine
Green Machine's Avatar
Is the other side still attached ? You should be able to follow the firing order around the cap, the rotor turns clockwise, so if the wire is still attached to #2, the next wire will be #1 going clockwise.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 02-11-2009, 11:25 PM   #5
MyMach5
MyMach5's Avatar
"Is the other side still attached ? You should be able to follow the firing order around the cap, the rotor turns clockwise, so if the wire is still attached to #2, the next wire will be #1 going clockwise."
Thanks so much you guys. I got it figured out with your help. I was thinking the wires needed to be installed counter-clockwise in order to account for the direction the rotor was spinning...doesn't make any sense?...I agree...I over thought it. I gotta remember KISS.
I used the known goods and went from there. She fired right up.
Cheers!
