#26 |
Re: Project 50th C5 Blazer
that is coming right along, progress sure feels good, i like how things are looking.
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
#27 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
This is gonna be sweeet.
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#28 |
Tot Roddin'
This is going to a great build... definitely can't wait to see how this turns out.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#29 |
Out of the carpool lane.
Looks like fun Drew! I'm looking forward to seeing this in person.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
#30 |
Wide n'Low
![]() Join Date: Jan 2007
Well, after more delays with CPP, I canceled my order and went to Wes at Classic Heartbeat for the Super trac bar setup. It might be in tomorrow, and if so I will be pay him a visit, and be heading up to get some work done. In addition to that I will take along some calipers for the front and tabs for the rear axle to mount both the brake lines and shocks. That should get me closer to being able to put the tub back on and get the Blazer moved to my shop where it will all come back apart and the true restoration will begin.
I have also been researching the 50th Anniversary trucks, looking for the details on both the interior and exterior items to finalize my plans. If anyone has good source information on the 50th trucks, feel free to respond. Even if I have it, I think it would be good to get it listed in the build thread. Thanks, Drew
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
#31 |
I have the same idea for my Blazer too. But I am probably a couple of years from getting started on it. Make sure you swap out the section of the firewall so that you can put the hand-operated parking brake assembly from the 67-68's and see if you can find a instrument bezel with the lights and wipers switches both on the left hand side. It's the little details that will make it all that much cooler.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
#32 |
![]() Join Date: Apr 2005
Are you going to do a set of buddy buckets??
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#33 |
Wide n'Low
smbrouss70 -
I was thinking of that for sure. Since I am fabricating most of the rear parking brake cable arrangement, it sure makes sense for the overall theme. As for the dash, I have a 67-68 Tach dash already, and contemplating modifying it to a Tach / Vac Cluster. That of course is a long way off, but it's on my list. Hart_Rod - I have been going back and forth on the seating. The Blazer was originally a utility bucket one, and I traded those for sport buckets. Still I love the look of that Buddy Bucket you have.. I have to add that picture to my wish list and ponder that one some more. Where did you have your seat done at? or did you do that yourself - cause it is very nice indeed. I did get my hands on an original dash pad and a set of visors from a 50th thanks to Livrat.. I will post pictures of them as soon as I take some. One other area I keep bouncing back and forth on it the use of 67 or 68 front fenders. I love the 67's, but in reality 68 would be the correct choice.. Anybody have some feedback on that?
#34 | |
#35 |
Wide n'Low
Cool, I thought stllookn had one I saw in another post, guess it was the same one. Since he is in my neck of the woods, maybe I'll get a look at it first hand sometime. As for the 68 fender, I think your right, it's the right way to go.
Thanks, Drew
#36 |
Yeah, you definately need to keep the sidemarkers to make it look right.
One other thing that I was thinking would be cool was running some 20" Centerline smoothies, painting/powder coating the centers white leaving the rim polished and figuring out a way to mount some factory 68 dog dish hubcaps. I hadn't quite figured out how, but I do have the hubcaps.
#37 | |
#38 |
Putting in my vote for the white/gold buddy buckets!!!!!!
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold ![]() 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold ![]() 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! ![]() 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold ![]() ![]() ![]() 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70!!! (Sold) ![]() 2003 K2500HD 8.1/Allison1000/NP263 ![]() |
#39 |
Wide n'Low
Cool idea! I might have a line on a set I saw recently, I had better go look again.
#40 |
Member #1049
Drew.. here is a set of buddy buckets on Craigslist in Tacoma..
http://seattle.craigslist.org/tac/pts/1041001522.html See you in the morning!! |
#41 |
Wide n'Low
Cool, I will try and make contact. Thanks
I found a set down this way, but can't remember if the guy sold them yet or not.. I will find out Have not heard from Wes yet, but will head up anyway as there is always something to be working on... Brad said he should be able come along as well.
#42 |
Wide n'Low
I finally found a picture of a restored 50th. This truck belongs to Rick Parsons, and the article is in Truck Builder Magazine http://truckbuildermagazine.com/ME2/...49EDD04DB2C706
Pretty Damn nice ride! This helps me to visualize mine.. I am going to attempt doing a Photoshop onto a Blazer with the color scheme. ![]() ![]()
#43 |
[QUOTE=Twisted78SS;3153989]I finally found a picture of a restored 50th. This truck belongs to Rick Parsons, and the article is in Truck Builder Magazine http://truckbuildermagazine.com/ME2/...49EDD04DB2C706
Pretty Damn nice ride! This helps me to visualize mine.. I am going to attempt doing a Photoshop onto a Blazer with the color scheme. That's a pretty sweet ride......I hope my CrewCab comes out that nice...... ![]()
#44 |
Resident of Here
I'd love some Fesler smoothies.
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
#45 |
Tot Roddin'
That is one sweet truck.... definitely provides a great view for your build.
#46 |
Wide n'Low
Well, more progress today. Actually, Livrat has made progress this week already. He was able to finish the mock up on both the rear bag brackets and the C-notches. In addition, on went the upper shock mounts (using the 4x4 shock mounts moved back to achieve a better angle on the shock.
Here is where it was at today before we got started ![]() ![]() ![]() ![]() Also installed were the transmission cross member, the Automatic transmission linkage bracket, and the motor mount towers. ![]() So we began to work on the brakes, installing the rear caliper brackets, calipers and assessing what to do about brake lines. The rear hoses are actually 72 Chevy 4x4 front brake hoses. ![]() I put the front calipers on, but forgot to get new hoses.. Since the calipers are all the same on these trucks and Blazers from 71 to 78, I am using a set from my 77 2wd Blazer. Next, in went the gas tank. We also discussed the remaining welds that need finishing. Gussets for the bag brackets C-Notch Lower shock mounts Next it was time to get the tub back on. (Well at least temporarily for the trip to my shop so I can take it all apart again!) ![]() ![]()
#47 |
Wide n'Low
And Here it is!!
![]() ![]() Taking a look at this next shot reminded me to mention something. My stock front shocks are to long! They bottomed out, and are holding up the front end.. They gotta go; ![]() ![]() So, after a few hours of work, we selected the front sheet metal.. I decided to go with 68 fenders after all. Next steps are to get the front end on, and load it up for the trip down to my shop. The project moves into phase two, the restoration. It will all come back apart for the restoration.. I am sure things will slow down a bit for awhile, while I assemble parts and refurbish others. Moe to come for sure. Drew
#48 |
This is going to be one sweet ride!! Definately going to be watching this build.
#49 |
Looking good man! That makes me want to go work on mine.
#50 |
Commander Taco Bello
i need a blazer. these look bad ass sitting on the ground.
