Old 02-15-2009, 03:04 AM   #1
justcuz
justcuz's Avatar
RPO Codes
I looked around and could not find the answer. My 1973 Suburban has a couple of RPO codes I can't decipher. All of the codes are preceded by the number 1. The ones I want to figure out are 1G86 Eaton lock and Diff. Is this the same as a G80? The other is 1ZN8 Optional axle ratio, what ratio is it?
Any help is appreciated, Thanks.
justcuz is offline   Reply With Quote
Old 02-15-2009, 12:53 PM   #2
LONGHAIR
Re: RPO Codes
I'm pretty sure that the G86 is the bigger version used in 14 bolt differentials. Basically the same as the "Gov Lock" G80, just bigger.
AFAIK the NZ8 is 3.73-1 gears
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 02-15-2009, 01:13 PM   #3
justcuz
justcuz's Avatar
Re: RPO Codes
Ok thanks, I'll confirm all this when I pull the rear cover, but this vehicle is not on my short list of things to do. Actually I was just doing my once every 3month hood hinge lube to prevent bending the hood. I decided to check the fenderwell tag. I forgot to mention that this is a C20 Suburban (3/4 ton 2wd).
I am familiar with the G80 and GM now uses it for everything regardless of model. However 1973 was the first year for the 14 bolt corporate rear axle and I wondered if it may have had a different RPO code that first year. i was also kind of hoping it meant a No-Spin Detroit locker in spite of it clearly sayiing Eaton on the tag. The difference between the 3.73 and 4.11 is not too great, but every little bit helps these days. It will probably get a 700R4 down the road anyhow. I also have a way to eliminate the flyweight and gear mechanism, add frictions and shims to make these G80 rear ends completely trouble free. When I do another one I'll post a thread.
Old 02-15-2009, 02:34 PM   #4
rick1956
rick1956's Avatar
Re: RPO Codes
I've got a master listing of the RPO codes (not sure where I got it originally), and I don't see any with a "1" preceding the 3-letter designation.
For anyone that wants the PDF file, here's a link to it
I may be old, but I still enjoy the feeling
of the earth rotating beneath my wheels...
rick1956 is offline   Reply With Quote
Old 02-15-2009, 02:48 PM   #5
b454rat
Re: RPO Codes
The Eaton is acutally a posi, whereas the newer ones are the Govlock...
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
