02-15-2009, 08:45 AM | #1 |
GTO IRS in c10
I have been thinking of what to do with the suspension on my truck and would like to float an idea. What do you think of using a GTO rear sub assembly in our trucks? A guy on e-bay said he has a bunch of these and at first glance it looks like it may be able to work with our trucks. While I know someone like Nate or Scotts could graft them in and make them work, the big question would be how hard would it be to do so and would it be worth it for someone like Nate to make an install kit?
The assembly has 3.46 with locker, disk brakes, 5x4.75 bolt pattern, and a backing plate to backing plate measurement of 58". The front mount holes are 48" apart and the rear mounting is in the center behind the dif. The driveshaft connects through a rubber bushing so something would have to be done to connect it to a standard U-joint. The GTO weighs ~3800Lbs and the assembly is designed for a 400HP LS2. So the questions are: Will it work without a massive re-engineering effort? What ride heights could be done? Would anyone be interested? |
02-15-2009, 10:36 AM | #2 |
Re: GTO IRS in c10
Killer price. $300, damn! I think the complexity would depend on the dimensions and where everything would line up with the frame.
You would need to z the frame and build some crossmembers to pickup the mounting locations. Then build some spring pockets. I don't know if it would be worth it, unless you are looking for something different. You would probably improve the ride quality and maybe improve handling. I don't think it will help you get the truck any lower.
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= Douchebag Racing: Runs Fine all the Time |
02-15-2009, 11:18 AM | #3 |
Re: GTO IRS in c10
For myself, I am not looking to lay frame, I am more into the handling side for every day driving. Something like a 3-4" drop is the stance I like but I'm not sure why you said a frame Z would be needed. I agree some cross members and spring pocket or coil over would be needed, but doing the Z would take the bolt on Kit aspect out of the options and I would like to keep the bed standard. As I am not very knowledgeable on suspension fabrication, why do you think a Z would be necessary?
I do like the something different part, but also the disk and locker for the price looks good. |
02-15-2009, 10:06 PM | #4 |
Re: GTO IRS in c10
I said z-ing the frame because I figured you would want to go low. With a 3-4 inch drop you might not have too. Like I said though, it is really going to depend on how everything lines up.
For that price though it may be worth getting it to see how it fits under there. I would see if you could get some dimensions first.
02-16-2009, 08:45 AM | #5 |
Re: GTO IRS in c10
wild83c10 Thanks for the tip.
Would anyone else be interested in this type of setup or is this a hair brained idea? |
02-16-2009, 09:50 AM | #6 |
Re: GTO IRS in c10
Why not a jag irs or even one out of a thunderbird both would be cheaper.
02-16-2009, 10:28 AM | #7 | |
Happy to be here
Re: GTO IRS in c10
While the purchase price is very reasonable, you have to factor in other costs. Since it sounds like you might not have the ability to do the fabrication work it would require for the install, that will add considerable cost. It will also require some R&D which translates to trial & error unless you are lucky enough to get it set up correctly the first try. I'm guessing from my experience on such ventures that it's not going to happen. If you just won't a mild drop with a suspension that handles better that what you have, I think there might be better ways to accomplish that goal.
02-16-2009, 10:34 AM | #8 |
Re: GTO IRS in c10
I haven't looked at the T-Bird, I was looking at the GTO because it is a modern rear, 3:42, Disks, track lock, and designed for 400HP in similar weight. As a plus, $300 for the complete setup looked like a deal. Has anyone done this type of IRS? I have seen the Jag setup on hot-rods but I think parts would be way north of $300...
02-16-2009, 11:02 AM | #9 | |
Re: GTO IRS in c10
When I first thought about this I was thinking it would be great to have a Kit like the Dropmember C4 but given the responses thus far it may be barking up the wrong tree but I figured no harm at least posing the question |
02-16-2009, 11:43 AM | #10 |
Re: GTO IRS in c10
It sounds like a good idea, but i had an 04 gto and these things are not strong. Always bending and breaking the stub shafts. The cvs and the halfshafts are way undersized, even if you step up to the 05-06 model year. They also have to have the craddle shimmed and aligned to work properly. If you go with a complete aftermarket lsd from kazz you are looking at 3500-5000$, most people making big power do this or solid axel swap. There are some companies like pedders that make aftermarket bushings and harrop makes a good cover all of which is expensive. Check out www.ls2gto.com. It is a good forum that can give you loads of info on these units. Just my experiece and .02 cents. After 18 months, 2 craddle adjustments, 4 stub shaft, one stuck side gear, and one twisted half shaft enough was enough for me. BTW mine only had 345 horse and torque at the wheels, it was a 6 speed with 24k on it.
67 gmc 1/2 ton, 5.0 v6, 4 speed SOLD!! 70 Chevy C-10, 355, th400, 3.73's 2/4 drop |
02-16-2009, 12:17 PM | #11 |
Re: GTO IRS in c10
after closer inspection of the pics, if you can incoperate the craddle into your frame somehow it would be better, however the strenght of the parts is still to question. BTW the rubber isolator is a big downfall due to the give, but there are companies that make one piece non rubber replacements($$$$)
02-16-2009, 01:21 PM | #12 | |
Re: GTO IRS in c10
I know of around 6 or 7 gto's in tulsa that are making 390-500+ rwh and none of these guys have broke a diff. Clutches, yes, but so far no one has had any problems with the rear. And all of these guys are track regulars on drag radials.
Doug Looking for a 67-72 short bed driver..... Last edited by m6z; 02-16-2009 at 01:23 PM. |
02-16-2009, 01:27 PM | #13 | |
Re: GTO IRS in c10
http://bmrfabrication.com/GTO.htm
Doug Looking for a 67-72 short bed driver..... Last edited by m6z; 02-16-2009 at 01:28 PM. |
02-16-2009, 03:53 PM | #14 | |
Re: GTO IRS in c10
02-16-2009, 10:57 PM | #15 |
Re: GTO IRS in c10
Never tracked the car, couple of dyno runs. The whole time i owned it i put less than 5k on the car. Just a bad lsd. Solid axle is the way to stay. The gto club i was in out here in Cali. had broke diffs all the time. Maybe we just drive them how they were meant to be driven?
02-24-2009, 12:32 PM | #16 | |
Re: GTO IRS in c10
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
02-24-2009, 02:49 PM | #17 | |
Re: GTO IRS in c10
No one has even broke a drive shaft or the rubber coupler that connects it.
Doug Looking for a 67-72 short bed driver..... |
02-24-2009, 10:14 PM | #18 |
Re: GTO IRS in c10
I would hook great on the streets with dot slicks, but it was short lived. I had the thunk in the trunk, pegg leg, cradle adjustment problems, and leaks. Got better with a cover and great bushings. Not a bad concept just terrible parts. Keep looking for a "better"center section. Maybe a Vette's.
02-25-2009, 01:11 PM | #19 |
Re: GTO IRS in c10
The bolt pattern in not quite 5x 4.75. High Performance Pontiac did an artical about putting GTO wheels on a Firebird and had to enlarge the holes slightly. It's only a few mm, but worth noting.
I can still count my vehicles on two... wait three hands. |
02-25-2009, 02:33 PM | #20 |
Re: GTO IRS in c10
This is similar to using BMW wheels on a 4.75" GM car pattern which is a popular swap for guys wanting a 'touring' look wheel on a budget. They'll physically fit but ultimately you run the risk of torsional twist causing the studs to fail (thus it is dangerous). It may not happen to everyone, but it can (and has) happened.
02-25-2009, 09:24 PM | #21 |
Re: GTO IRS in c10
Well... Not much interest in the kit concept with the GTO IRS and with questionable capacity so.... anyone have any other new ideas for IRS? I know the vette system has been done but the parts are $$$, was looking at the Charger/300 rear setup but it's higher priced than the GTO, no locker and lower gear ratio and I am not sure if it’s rep is better or worse than the GTO.
02-25-2009, 10:07 PM | #22 |
Bodydropped71
Re: GTO IRS in c10
I wouldnt go for the crysler/dodge IRS. I own a dodge charger and theres some things i dont like about it. Some knocks when switching gears sometimes and a few other things.
02-25-2009, 10:50 PM | #23 |
Re: GTO IRS in c10
How 'bout an Expedition 8.8 IRS?
02-25-2009, 11:17 PM | #24 |
Re: GTO IRS in c10
Same thing with the goat. There is a lot to be desired with drive line slop in the IRS cars. This is one thing that really messed with me on this style. They spend so much time making it fit that form becomes second to the functionality. I replaced almost all of mine by the time it was said and done and 4k later i cut my losses. Its not a bad rear end, but it ain't good either.
11-04-2016, 07:06 PM | #25 |
Re: GTO IRS in c10
