Old 02-16-2009, 10:40 PM   #1
cleszkie
cleszkie's Avatar
Headers to 2.5" Ramhorns
Well, I finally got fed up with dealing with my headers. I could never get them to stay leak free for very long at the heads, and the crappy ball and socket "gasketless" collector connnections never sealed due to the ball portion continually crushing down when you tried to tighten it (Hedman headers). It was always a PITA to change spark plugs, and it was hard to route the plug wires without one or more of them getting cooked. The last straw was when I resorted to wrapping the top 3 inches of the the two inner header tubes on each side with a header wrap to protect my plug wires. Well, the cheapo headers couldn't handle this. The wrap prevented the headers from dissipating the heat, and the tube on my #6 cylinder blew out a quarter size hole under the wrap while I was accelerating on the freeway (after being wrapped for about 2 years). When I removed the wrap from the other side, the two inner tubes were all heat deformed and as brittle as glass! Now I know why wrapping headers voids most warrantees. Sure, most of these problems could be fixed with a real set of high quality headers, thick aluminum gaskets, and anti-loosening fasterners, but I have had my fill, and don't have the money for ceramic coated Doug Thorleys.
So to make an already long story a little bit longer, I ordered up a set of 2.5" ramhorns (Dorman Corvette knock-offs for $78 each), cut of the accessory flanges with my angle grinder, bolted them up, spliced in the required exhaust tubing to mate up with the back end of my exhaust system, easily put in the plugs, rerouted the plug wires to the dizzy and fired it up. No leaks, quieter exhaust tone from under the hood, and the peace of mind that they wont blow out - priceless. Sure, they may not flow as well as the headers, but from what I've read, they should flow well enough for the HP I'm making. I seriously recommend this "upgrade" to anyone running a set of leaking cheapo headers. I can supply the GM part numbers for the OEM manifolds (more expensive when new), and the Dorman part numbers if anyone is interested.
I got this idea from this board. Yet another reason why I love this board so much!
cleszkie is offline   Reply With Quote
Old 02-16-2009, 10:54 PM   #2
Mike C
Mike C's Avatar
Re: Headers to 2.5" Ramhorns
Great mod! I did the same thing on mine. My butt-o-meter suggested more low end torque and at least same HP. I have a little cam, though. Crane 266, about same as a Comp 260. I also went to 2 1/2" exhaust at the same time up from 2 1/4".
I've got a 4x4 '86 dually with a big block that someone put 2 wheel drive headers on and had to pull the front driveshaft. Me thinks manifolds are going on there as well.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-16-2009, 10:56 PM   #3
jaros44sr
jaros44sr's Avatar
Nice upgrade, did you use brass nuts on your flange studs? Are you going with or without gaskets between the head and exhaust manifold?
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 02-17-2009, 01:43 AM   #4
cleszkie
cleszkie's Avatar
Jaros44sr - The Dorman ramhorns come with studs, washers, lock washers, pinch nuts, and manifold donut gaskets. I used one washer, one lock washer, and a pinch nut on each of the studs with a dab of anti-seize. What is the benefit of using brass nuts? Do they resist corrosion better?
The instructions that came with the manifolds suggested that they be installed without gaskets between the manifold and head for optimum sealing. However, I was not certain that my heads were perfectly flat to mate to the manifolds, so I used the Felpro semi-metal gaskets for a stock application (part #MS 9275 B).
BTW, the Dorman part numbers are 674-504 and 674-503 for the right and left manifolds.
Old 02-17-2009, 01:55 AM   #5
67_C-30
I have a radical idea!
67_C-30's Avatar
I quit running headers on anything but a racecar long ago because of this. There are some headers out there that will seal up, but they are expensive and still cumbersome to work around. I think you'll love your ramhorns!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 02-17-2009, 02:36 AM   #6
project 67 sub
project 67 sub's Avatar
thats what i plan on putting on my burb..... hate my d@#N cheap a$$ leaky mr gasket brand headers
project 67 sub is offline   Reply With Quote
Old 02-17-2009, 09:40 AM   #7
jaros44sr
jaros44sr's Avatar
The brass won't oxidize, so it will allow you to unscrew the nut by hand once you break it loose, anti-sieze is a must, higher temp one preferred. If you have long studs this can be an advantage, hard to get a wrench in there. Racket wrench may work. Gaskets, no gaskets is an ongoing debate, I just use a copper shield spray on...if there is no gasket there it can't blow out, but as you state, surfaces have to be flat
JMO but lock washers are useless, since when they get hot, they lose their tension, locking tabs are better cause they maintain proper torque, and I'm sure that this is why you will blow a gasket in the first place. Hot and cold cycles back out the bolt
Simple check is to put a strait edge on the heads, look for light, use a flashlite
SAFETY FIRST
AS usual, off topic
Jim
Old 02-17-2009, 11:14 AM   #8
Yukon Jack
Yukon Jack's Avatar
Did your ramhorns have the heat tubes that kind of run diagonal near the bottom of the collector?
I've heard some people drill them out and fill the hole. Just curious to see what you did. I've got a pair ready to be installed but I painted them before seeing that maybe I should have removed that heat tube.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 02-17-2009, 11:16 AM   #9
Critter
Future TOTM Winner
Critter's Avatar
I have a whole list of guys that I want to read this post. I have been preaching this same idea to local "gear heads" for years with few people actually listening to me. I got fed up with cheap headers about ten years ago and started ripping them off of all the old junk I had. Like everyone else has said, you can spend a grand and get something that won't leak, but on a street/trail truck it just isn't worth it in my opinion. Now, when I finally build my 12 second street legal swb truck...that might be a different story.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 02-17-2009, 11:35 AM   #10
jaros44sr
jaros44sr's Avatar
Drilled and knocked out tube...do it now, because A it will rust out, and 2, you'll have to pull the manifold to tap the bottom hole. Maybe you will have clearance to tap it with the manifold mounted, but it could be difficult
Now that I think about, once I knocked out the tube, the hole was just the rite size to be tapped for a 1/8" NPT
SAFETY FIRST
AS usual, off topic
Jim
Old 02-17-2009, 12:35 PM   #11
fun in dirt
fun in dirt's Avatar
Y'all have convienced me to go this route too!
So are the vettes the only thing that had manifolds like this or is there others I can seek out in the junkyard too?
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
[B]'85 C10 [B] "Corpse"
'01 2500 Suburban ...party wagon & tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 02-17-2009, 01:04 PM   #12
see ten
WTB this ad
see ten's Avatar
I've always ran manifolds instead of headers myself! The ramhorns are supposed to have excellent flow as well.
On a side note, I thought the Hedmans were supposed to be good headers. Were yours the thinner uncoated ones or the thicker gauge headers?
see ten is offline   Reply With Quote
Old 02-17-2009, 03:52 PM   #13
cleszkie
cleszkie's Avatar
Yukon Jack - Only the passenger side manifold came with the heat tube. I left it in, but after reading what Jaros44sr said about it rusting out eventually, I think I will be drilling it out and filling it.
See Ten - I think I must have had the thinner, uncoated headers. They came in a black primer. Under $200 for the set from Summit. It was the heat wrap that destroyed them, but the ball and socket collector connection should never be used on a thin gauge header because it just crushes down like a crush sleeve everytime you tighten it, or when the motor moves on its mounts.
Old 02-17-2009, 04:00 PM   #14
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
WOW, great mod
(*I had Headman Elites w/ ball flanges & mine
never leaked, but I may have had a good pair)
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 02-17-2009, 04:26 PM   #15
70rs/ss
70rs/ss's Avatar
You can order two of the rights or lefts, as the vette ramhorns are a straight dump and will work on either side, so if you remember which one has the tube in it, buy two of the other side and you will not have any issues with tapping anything??
70rs/ss is offline   Reply With Quote
Old 02-17-2009, 05:40 PM   #16
Blazer1970
Blazer1970's Avatar
yup
Blazer1970 is offline   Reply With Quote
Old 02-17-2009, 07:31 PM   #17
Mike C
Mike C's Avatar
Speedway Motors sells a high flow "rams horn" style manifold. $300 I think for the cast iron, and $400 for the cast stainless. That's a pair.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 02-17-2009, 08:04 PM   #18
Skirkpat
Skirkpat's Avatar
Good move, you wont regret that.
Skirkpat is offline   Reply With Quote
Old 02-17-2009, 08:32 PM   #19
72freak
Rottenwood Garage Member
72freak's Avatar
I have had many many automobiles and I am normally a slow learner...BUT......after 1 pair of headers 20 years ago I have never bought another set and I dont plan on it either. Good move!!!
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 02-17-2009, 10:17 PM   #20
Critter
Future TOTM Winner
Critter's Avatar
So which side DOESN'T have the tube??? So I will know which to order next time I need some.
Old 02-17-2009, 11:27 PM   #21
jaros44sr
jaros44sr's Avatar
the side that has the flange cast into it has the tube, the cast flange is for mounting the generater/ alternater...so get the other side
SAFETY FIRST
AS usual, off topic
Jim
Old 02-18-2009, 07:36 AM   #22
vtblazer
vtblazer's Avatar
Welcome to the 2.5 club.
Watch those center plug boots, they like to burn through.
vtblazer is offline   Reply With Quote
Old 03-04-2009, 09:45 AM   #23
jaros44sr
jaros44sr's Avatar
Originally Posted by lks dcvn View Post
I got lucky and got a set from JC Whitney for [drumroll please] - $75 shipped.
If you go to the JC Whitney website and then do a search for item #674503 - it will come back with the corvette 2.5" center dump ram horn - I tried to order 4, but they shipped 2 and then told me they were discontinued after that.
I got them and they are the Dorman set with all the mounting hardware in the boxes...
They are going on my Dad's truck when I get it out of storage for the winter (April).
That is quite the deal, didn't know Whitney was still in business
SAFETY FIRST
AS usual, off topic
Jim
Old 03-04-2009, 07:06 PM   #24
cleszkie
cleszkie's Avatar
Thought I would update my ramhorn install with one last bit of info. As was pointed out, the center plug boots like to burn after a while. So to combat this problem, I installed a set of the stock metal plug shields. Bought them new through a local aftermarket shop. Super easy install - the shields bolt to existing tapped holes in the block below the heads. Took about 20 minutes to install. $20 for the set of four shields. Hopefully they work, because they look alot better than a bunch of silver heat wrap on the plug wires in my opinion.
Old 03-04-2009, 07:08 PM   #25
jaros44sr
jaros44sr's Avatar
Got pics.? Welcome to the 2.5" club as VT put it
SAFETY FIRST
AS usual, off topic
Jim
