Old 02-18-2009, 02:54 AM   #1
sams60gmc
sams60gmc's Avatar
Question quick disc brake question
So I read the sticky about the disc brake swap and I didn't really see what I was looking for. So here's my question. I have a 60 gmc (torsion style) and I've got a bunch of leads on complete front ends (coil spring) is it possible and how hard is it to switch it over?? Thanks alot guys!
sams60gmc is offline   Reply With Quote
Old 02-18-2009, 12:31 PM   #2
mnky30
mnky30's Avatar
Re: quick disc brake question
you can just take the hole front cross member out of a 80 1/2 ton trucks and just in stall it in to your truck. remove your old x member and put the newer 1/2 ton x member in you will have to drill some new holes to make it fit. here are some pics of my 60 i did.
vinnie
1960 chevy c10 frame with a 1966 cab
2002 dodge intrepid r/t
2004 chevy 2500 4 door short bed
mnky30 is offline   Reply With Quote
Old 02-19-2009, 01:09 AM   #3
Captainfab
60-66 Nut
Any 1/2 ton pickup or Suburban front suspension from 1971 to 1987 will bolt in with minor work. I've not done on in a torsion bar truck, but in the '63-'70 trucks you need to drill one hole on each side and elongate one hole on each side.
Old 02-19-2009, 03:00 AM   #4
sams60gmc
sams60gmc's Avatar
Thanks for the help guys. Im gonna try and buy a 73 front end from a guy that I emailed off of CL and see if he still has it. I'll store it til I can borrow my Dads garage then start tearin stuff off!!
Old 02-20-2009, 12:41 AM   #5
sams60gmc
sams60gmc's Avatar
so this is probably a no seeing as everyone goes to 5 lug. But is there any one that makes a 6 lug rotor for the 73 set up I'm looking to install?
Old 02-20-2009, 12:44 AM   #6
joe231
joe231's Avatar
believe truckandcarshop.comhas them...i'll look
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 02-20-2009, 12:53 AM   #7
502tripower
502tripower's Avatar
I think CPP dose as well...http://www.classicperform.com/6092ch...20Brake%20Kits
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
