Old 02-18-2009, 08:21 PM   #1
DADS71
DADS71's Avatar
No hi beams and volt gauge left of center
Hi guys I need some opinions ,no hi beams thought it might be a fluke, so replaced lamps and pulled light switch, they came on.(fixed I thought) started it up later and no hi beams noticed gauge showing not charging took alternator in for test showed it was charging pulled voltage reg off another of my trucks and tried that didn't help, seems like even lo beams and instrument lights are dimmer than usual. any ideas?
DADS71 is offline   Reply With Quote
Old 02-18-2009, 08:49 PM   #2
Andy4639
Old member
Andy4639's Avatar
Re: No hi beams and volt gauge left of center
I'm no expert but I would look for a ground wire and then the head light switch itself. Then the dimmer switch.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-19-2009, 03:26 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
start with the dimmer switch, it is the weak point in the system.
As for the amp guage reading low... you aren't charging for some reason.
Old 02-19-2009, 04:01 AM   #4
enaberif
Low volts = weak alternator or a loose alternator.
Loose alternator will do 1 of 2 things; improper charging and slipping belt.
Both of which isn't good.
enaberif is offline   Reply With Quote
Old 02-19-2009, 08:58 AM   #5
cdowns
cdowns's Avatar
i'd start by checking to see if you get 12v at the bulb ,could be hi filament on both bulbs is bad// if not 12v at the bulb then to the dimmer switch
Old 02-19-2009, 02:10 PM   #6
ckhd
ckhd's Avatar
The high beams is most likely your switch on the floor. They either go bad, or even work the wire loose.
Check the connector on the switch first, that's my bet.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
