02-20-2009, 10:58 PM | #1 |
Porterbuilt- Weld-in Notch- Free Shippping- Till March 31
Hey guys, I finally got around to getting my weld-in notches all finalized. It's a "mostly welded" weld-in notch, and I have two versions: 63-72; and 73-87.
As pictured they will lay frame with up to a 32" tall tire. If you're running a smaller diameter tire, or not quite wanting it so deep, you can trim it down to fit, or I can build them shorter. Below are some pics of both versions. They come as pictured, including the ground and finished edges. The "Mostly Welded" notch kit runs $299, and the "Unwelded" notch kit (pieces only) runs $175. I will be throwing in free shipping anywhere inside the continental U.S. until the end of March.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! Last edited by PBFAB.COM; 02-25-2009 at 12:20 AM. |
02-20-2009, 11:02 PM | #2 |
Re: Porterbuilt Weld-in Notch
02-21-2009, 12:54 AM | #3 |
What no install pic's! Slacker
Kevin LFD Inc. |
02-21-2009, 01:06 AM | #4 |
I don't work quite as quick as you do! I guess it's because I am human, and have to get more than 3 hrs. of sleep a week!
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
02-21-2009, 08:18 AM | #5 |
NICE!! those things are a work of art.
-02 avalanche (daily driver) -66 gto ragtop 389/400 (garage queen, hand-me-down from dad) -72 Tribute Trans Am (6.0LS/T56 6-speed) in progress -2003 YUKON (Wife's) -71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain) -48 3100 SWB - 12/31/23 LONG TERM Project |
02-21-2009, 12:33 PM | #6 |
big guy
Hey Nathan your not going to give a set away are you You know where you put guys names in a hat and pull one .... just asking, I feel lucky!!!
looking great as always Nathan! Sorry coudn't help myself! |
02-21-2009, 12:57 PM | #7 |
Nate,
Do these come with instructions on where to weld them in? I have never done this and i am going to do it. I was going to purchase the bolt on system, but if these come with instructions on where to place them to weld them, i know an awesome welder that could get it done for me. Options are always great and if i can save a few bucks in the process, even better. |
02-21-2009, 01:07 PM | #8 | |
Josh
(Project truck) 1970 C10 under complete transformation My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
02-21-2009, 01:41 PM | #9 | |
When locating the center-line of the axle (and thus centerline of the notch) I have found that the original bumpstop's centerline is about as close to the center of the wheel arch as you need to get. I use that as a centerline reference. With that said, here's the tricky part: depending on whatever link system you are using to locate the rear-end, the length of your link bars will follow an arc and thus locate the center-line of the axle in different locations as it goes through its travel. I like to set the axle to where its centerline is centered in the wheel well opening when deflated (if running an adjustable suspension). That way it looks "right" when everybody is taking pictures of it at the show! It takes some careful measurements, but isn't overly complicated. Just take your time, measure several times before cutting/welding... and several more times before you fully weld them up. I am happy to answer any questions that may arise. I know that a lot of the time it's easier to "talk" someone through a process, rather than "type" the way through it.
02-21-2009, 01:43 PM | #10 | |
02-21-2009, 02:33 PM | #11 |
I want one! Sending PM
02-21-2009, 09:07 PM | #12 |
Tot Roddin'
Another great product brought to you by Nate!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
02-23-2009, 10:51 AM | #13 |
Re: Porterbuilt- Weld-in Notch- Free Shippping till March 31st
Nate..... How 'tall' is the actual boxed section of frame? By that I mean just the frame rail & not 'how tall is the notch'. If the question is confusing, call me.
02-25-2009, 12:20 AM | #14 |
The notch thickness is approx. 4".
02-25-2009, 12:21 AM | #15 |
I went ahead and editied my first post:
I also sell the kit in unwelded form. It runs $175. The same free shipping applies through March.
03-03-2009, 12:50 AM | #16 |
how wide is the top of the notch outside to outside?
i want one for my 72 blazer and still use the seat! whats retail price gonna be after march? i want to know how many i should buy??? |
03-03-2009, 11:25 AM | #17 | |
After March 31st I will be charging shipping... so $299 plus shipping!
