Old 02-20-2009, 11:55 PM   #1
Luis_gz06
Luis_gz06's Avatar
Electric Choke Q-Jet On 67-72??
For the people that have stock electric choke Q-Jet carburetor's on your 67-72 trucks, how do you make it function? I have one installed on my 70, but dont know where to get the circuit to make it work. Anyone knows where to splice a wire or hook it from? Thanks!!
1972 Chevrolet Blazer 4x4 (Almost done stay tuned)
1970 Chevrolet Pickup Longhorn CST/20 (SOLD)
Luis_gz06 is offline   Reply With Quote
Old 02-21-2009, 12:57 AM   #2
sbrad701
Re: Electric Choke Q-Jet On 67-72??
You should be able to pull from any 12V source as long as it is only hot while ignition is on. If not a fused source I would add a fusible link. I believe Holley recommends 10A fuse so you should be fine with that on Rochester also. I would NOT connect it to the coil. That could possibly cause you problems. Hope this helps.
If It'll roll I'll race it!!!
sbrad701 is offline   Reply With Quote
Old 02-21-2009, 08:12 AM   #3
68C15
blood type; Retumbo
68C15's Avatar
I went to the fuse box.
tapping into the coil feed will cause driveability issues.
68C15 is offline   Reply With Quote
Old 02-21-2009, 10:17 AM   #4
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
I think the M&H Harness I have taps power from the starter somewhere.
All I know it looks clean!
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 02-21-2009, 05:15 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I don't see where there would be a wire on the starter for this... the starter has one wire that is hot all the time (bettery cable) one or two wires (depending on ignition system) that is hot when you are holding the key to start... that's it.
As indicated above, you need a key on source... ignition unfused is a perfect place. That would be a 10 amp fuse... not 10 volt.
Old 02-22-2009, 11:36 AM   #6
Sport/Truck
Sierra Grande Club
Then I must be wrong on this. I'll try and look to see where it's coming from.
s/t
Old 02-23-2009, 07:52 PM   #7
sbrad701
My appologies for the typo longhorn man. It is now corrected.
Old 02-24-2009, 01:38 AM   #8
spinning wheels
spinning wheels's Avatar
Luis, I checked my wires on my truck. I installed an Edelbrock 1406 around 9 years ago, so my memory is rusty.
Seems the red, (hot wire), goes from the choke to the positive side on my ballast resister.
From there the hot wire, goes into the fuse block under the dash, to a 12 volt power source.
My truck originally had a divorced choke, so I didn't have a power source, when I installed the 1406.
Hope this info helps.
'72 GMC custom camper 350/350
spinning wheels is offline   Reply With Quote
Old 02-24-2009, 07:00 AM   #9
Blazer1970
Blazer1970's Avatar
I used the switched hot wire that goes to the connector for the TCS relay. Most trucks have it hanging there unused anyway. Just crimp on a male spade connector and plug it in there.
Blazer1970 is offline   Reply With Quote
