02-21-2009, 09:50 PM | #1 |
Here's a good question for the suspension gurus
I did a suspension swap on my '68 chevy with '84 chevy 5 lug disc. I know that you can put 88-98 spindles on the a-arms of the 68 by changing the bottom ball joints. Could you put 88-98 spindles on the a-arms of the 84? Help needed.
'84 swb chevy '69 swb chevy '68 swb chevy '95 Impala ss-sold '89 chevy crew cab dually 3+3 |
02-21-2009, 09:51 PM | #2 |
Re: Here's a good question for the suspension gurus
Yes. It still requires using a 3/4 ton lower a-arm because of the need for the larger diameter lower BJ.
02-22-2009, 12:25 PM | #3 | |
What does the 88-98 spindle do for you?
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
02-22-2009, 12:36 PM | #4 |
six lug rotors and newer style calipers
CHEVY ONLY |
02-22-2009, 01:03 PM | #5 |
I haven't personally compared the two spindles, but one would need to verify the spindle height, and stering arm location of the two spindles. It would be my first assumption that they are NOT the same. If they are not the same, you will encounter issues with the suspension and steering geometry.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
02-22-2009, 01:30 PM | #6 |
67-72 parts collector,…
Wouldn't be easier to just change the rotors to aftermarket 6-lug rotors and be done?
02-22-2009, 07:26 PM | #7 |
Agreed x2.
02-22-2009, 10:26 PM | #8 |
with the newer spindle, you can get parts at a local part store and not have to special order.
there are a few on here that have done the swap......
CHEVY ONLY |
02-22-2009, 10:30 PM | #9 |
The only special order part would be the rotor itself. Everything else is standard 5-lug parts that are also readily available at your local auto parts store.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 02-22-2009 at 10:52 PM. |
02-22-2009, 10:33 PM | #10 |
uh...yeah...that was my point, if you need a new rotor you have to order an aftermarket part.....some would prefer using OE parts, and being able to buy replacements locally....
CHEVY ONLY |
02-23-2009, 11:41 AM | #11 |
Fabricate till you "puke"
Just a thought......If you purchase new aftermarket rotors, you will likely see 40-50 thousand miles service from them, as there is enough "meat" on them to turn them 2 or 3 times IMO, in the long run you will save yourself some bucks, & a bunch of work.....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
02-23-2009, 01:36 PM | #12 |
Some guys like the challenge of locating the required 3/4-ton lower control arms .
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-23-2009 at 01:41 PM. |
02-23-2009, 01:46 PM | #13 |
yeah i was just answering LONGHAIR's question....I didn't say it was a better option to each their own
CHEVY ONLY |
03-05-2009, 01:32 AM | #14 |
The reason I ask is because i recently went to a swap meet and there was a guy selling 2 in or 2 1/2 in drop spindles with rotors and calipers from a 88-98 chevy for 40 bucks. Whether i used them or not it was a deal but I let them go. Now i kick myself in the back side for doing so. Thank you guys.
03-05-2009, 08:37 AM | #15 |
the 88-98 spindle that work for the 6-lug conversion have to be 3/4 ton spindles (light duty 6-lug).
1/2 ton 88-98 won't work (5-lug). You did fine by not buying them.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 03-05-2009 at 08:37 AM. |
04-02-2009, 03:54 PM | #16 |
Modern day Fred Sanford
I did a search and found this thread so I'll ask my ??? here since it is somewhat relavent.
I am lookin at a 87 2wd 1/2 pickup that is 5 lug,I have a 88 model W/T 6 lug 2wd truck that is in bad shape.So here's my question,can I take the 6lug W/T stuff and put on the 87 to change it to 6 lug. I know everybody will want to know why and the reason is that I have a nice set of old school Boyd Posie II billet wheels that I bought several years ago and would like to put them back in use. |
04-02-2009, 05:30 PM | #17 | |
04-07-2009, 10:32 PM | #18 |
you can put a 88-98 light duty 3/4 ton 6 lug rotor on a 88-98 1/2 ton spindle. i converted my 99 2dr tahoe that way
