700r4 with Edelbrock carb (corrector bracket)
Is anyone running a 700r4 with an Edelbrock carb? Are you using the TV corrector bracket?
I was looking at these corrector brackets on the Summit website... TCI's bracket is $42.88 B&M's is $41.95 Hughes is $41.88 And the Summit house brand is $18.95 Now, all these brackets are pretty much the same, so one would be out of their mind not to get the Summit one, but let's face it- it's just a piece of metal. Anyone have one who could provide measurements to make one?
1988 R2500 Crew Cab Immediate plans- get it running! Future plans- Rear disc swap & Hydroboost Dually conversion with shackle flip-n-switch 4x4 conversion with 52" springs Maybe some new body panels ![]() Who needs a car when they make crew cab trucks? |
Low & Fast!
Re: 700r4 with Edelbrock carb (corrector bracket)
The Lokar stuff is even more expensive than the stuff I listed. I want to make the part so my cash outlay is 0.
The only measurement I need from someone running one of these brackets is the distance between the center of the bottom mounting hole and center of the 'relocated' TV stud. Anyone?
There's a diagram of the GM specification on what TV cable geometry should be with respect to the throttle shaft floating around somewhere. Wish I had the link to it.
1977 GMC Sierra Grande |
BAD BOW-Silverado XST
Here ya go homie!!
http://purplesagetradingpost.com/sum...o/700R4p7.html |
I would pay 18 dollars not to have that ugly job sitting next to my carb, but I guess it gets the job done.
Ken Morgan For fun: 1964 Volvo 122 For slow: 1984 Chevrolet C-10 For everything else: 1997 BMW M3 |
Parts and more parts
I built my own bracket out of metal plate and adjusted it to the proper distance for a good operation.
there's a few diffrent bracket's that will work for you. edelbrock has on for about $30-$35 buck's it bolt's to the intake manifold hold's the throttle and the t.v cable. specturm has one for about $15-$20 buck's bolt's to the back of the carb also hold's throttle and t.v cable. i just did a 700r4 swap in to my 73 blazer. the best thing to do is to go to your local transmission shop and buy a longer t.v cable.............i did yesterday if cost me $40 buck's installed............the t.v cable must be hooked up correctly if not you can and will fry your transmssion i hear..........also if you have a lock up converter you want it hooked up to work..............
Yea, gchemist, that looks like the piece I'm talking about- it bolts to the trottle arm of the carb and relocates the TV stud rearward. I just need to know the distance between the center of the lower mounting hole to the center of the TV stud.
What are you using for a throttle cable mount? Factory?
#15 | |
