Old 02-25-2009, 02:29 PM   #1
craig24671
craig24671's Avatar
wiper motor problems. Help!!!
I redone my truck with a painless harness. The first time I turned wipers on they worked. The next time I tried to use them Nothing! Although the squirters are working, I replaced the motor and still wipers won't work. I checked all the terminals on the motor and they all are getting power to them. the new motor has a good ground on the one bolt with the brass ground on it, I'm frustrated can anyone come up with any thing that i'm missing to get these fixed. thanx in advance
craig24671 is offline   Reply With Quote
Old 02-25-2009, 02:35 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: wiper motor problems. Help!!!
Wiper switch controls the ground. If you have power to the motor it might be a bad switch.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 02-25-2009, 02:52 PM   #3
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Like "Sinister" said, the motor is insolated from the mounts,power runs to the motor and it gets its ground from the dash switch(make sure your switch is grounded to dash).
This is so when you turn off the switch there is a switch in the motor that stays closed until the arms are down then it opens stopping the motor in the resting position.
sneakysnake is offline   Reply With Quote
Old 02-25-2009, 07:49 PM   #4
Botietruck
'71 chevy s.bed/s.side
Botietruck's Avatar
Had the same problem with mine. Had to get down to the metal-I scraped the paint off the rear of the switch mounting hole.
STILL PLAYS WITH CARS...AND TRUCKS!!
Parents! Be good to your kids...they get to choose your nursing home!
250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive!
Botietruck is offline   Reply With Quote
Old 02-25-2009, 08:50 PM   #5
craig24671
craig24671's Avatar
Sinister, Sneaky and Botie, thanks for the info. I did not know the switch needed grounded. I will check and see if it is metal to metal as soon as i can. Again thanks for the info. This is the best site for people helping people.
Old 02-26-2009, 02:12 AM   #6
NWD02
I just ordered a new switch through Ron Francis Wiring for my build and a new motor from O'Rielly's. I had to reseach a little to make sure they both worked together. There's the 3 prong and 4 prong motors.
NWD02 is offline   Reply With Quote
