Old 02-26-2009, 05:54 PM   #1
Skirkpat
Skirkpat's Avatar
Turbo 350 tailshaft ? will 9 " fit in truck
Is the 9" tailshaft transmission the same length as the stock 3 spd manual
Skirkpat is offline   Reply With Quote
Old 02-26-2009, 06:17 PM   #2
Tim Christian
Tim Christian's Avatar
Re: Turbo 350 tailshaft ? will 9 " fit in truck
No but a 6 inch tailshaft is. If you are changing from a six cylinder to a V-8 and putting the V-8 in the correct location than a 9 inch tailshaft Trans will work prefect with your orginal driveshaft.
Tim Christian is offline   Reply With Quote
Old 02-26-2009, 06:44 PM   #3
Skirkpat
Skirkpat's Avatar
Thanks Tim, The Suburban was originaly a I-6/manual , I just pulled a 350/3 spd manual out of it though, my mounts are bolted in the holes closer to the firewall.
So what you are saying is I can move my engine mounts toward the radiator 3inches and the V-8 with a 31 11/16 inch Turbo 350 will bolt in without changing driveshafts? If so I am a happy camper.
Thank you sir, you are the man!!!!
Old 02-26-2009, 07:22 PM   #4
Tim Christian
Yes, If you are using a 9 inch tailshaft and the V-8 in the holes closest to the Rad. support. Driveshaft and all should work just fine but right now it sounds like they used 6 cylinder engine stands you will have to get V-8 stands for everything to bolt up correctly. You will also need a automatic crossmember and need to remove the manual trans. crossmember. Hope this helps! Tim
Old 02-26-2009, 08:35 PM   #5
Skirkpat
Skirkpat's Avatar
Helps alot, I appreciate it, I already have a C-30 that I am stealing parts of off, I think most of what I need is there.
Old 02-27-2009, 09:48 PM   #6
Skirkpat
Skirkpat's Avatar
I had the guy measure the transmission ( which turned out to be a Turbo 400) and it measures 34 1/2 " , I know that the imput spline will be different, but now will I need to shorten my drive shaft to work in my Suburban?
