#376 |
Re: LFD's 4dr Tahoe Build
Thanks guys it really is turning out cool, even my wife is really digging it and she hated it when it came home!
Well I got the front two rows of seats mounted, can't believe it took most of the day. The second row mounts will double as the frame work for the closure plates for my under seat storage. I made mount plates for the front seats to make sure they were good because of the built in seat belts. All seat mounts have weld nuts so it makes things very easy to install and remove. Kevin LFD Inc. [IMG] ![]() [IMG] ![]() [IMG] ![]() |
#377 |
![]() Join Date: Apr 2005
Nice coffee table..........I mean wheel simulators....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#378 |
It's a multi use wheel table. It held my coffee this morning, my soda at lunch and by the time my DropMember shows up my real front wheels will be here. Thanks again for the hitch info it really helped. You will not believe how little space will be left when I am done. The center of the rear frame is filled with the tank, the out side of the frame will have my sway bar links and brackets, my 6 link bag set up, dual shocks and air tanks oh ya and exhaust! It is all going to fit and fit well but very tight.
Kevin LFD Inc. |
#379 |
![]() Join Date: Nov 2008
Kevin, thanks for the advise for proper tank flushing, u mentioned u got your tank off a blazer, was it a full size blazer? How about the sending unit? U said u got it new, but for a 87-91 ?
#380 |
Yes the tank is off a full size and is a 25gal. This one came from a pre 87 blazer that had a carburetor but it is the same as the 87-91 blazer tanks with TBI so I just ordered a later sending unit so I can do an in tank pump for my 05 Vortec. Now keep in mind it is a passenger side fill tank stock and if you have a SWB truck with coils it is a very tight fit. I installed one of these in LowBuck and show more about how tight it is in that thread. The sending unit will work with a stock 67-72 gauge with out any problems.
Kevin LFD Inc. Last edited by Rokcrln; 02-28-2009 at 10:07 AM. |
#381 |
Great info, please let me know what kind of in tank pump u are going with (Im going to try to get the same set up) I have heard of using a corvette fuel regulator, are u going to use one of those as well for your install?
#382 | |
For right now I will just be using the stock Truck Vortec fuel system that is on the fuel rails. Down the road I may swap over to the Corvette intake or a small air pumper ![]() ![]() Kevin LFD Inc. Last edited by Rokcrln; 03-01-2009 at 11:22 AM. |
#383 |
I used the corvette FPR on my burb. Here's some pictures.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 03-02-2009 at 05:42 PM. |
#384 |
chevy only
![]() Join Date: Sep 2006
kevin so trick! nice work those coys are going to look killer on there
CHEVY ONLY... Nothin Else ! |
#385 |
#386 | |
http://www.ls1tech.com/forums/conver...epside-10.html
#387 | |
Kevin LFD Inc. |
#388 |
My supercharger is set up for a single feed/no return. So vette FPR simplified the plumbing.
R/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 03-02-2009 at 05:41 PM. |
#389 |
hey do you know what do you have to do to change the c4 rear to 5x5 bolt pattern other than using an adapter?
#390 | ||
![]() Quote:
Kevin LFD Inc. |
#391 |
i have already ordered my rims and i have a scotts hot rod ifs and then today a friend gave me a c4 rear and i am also building a suburban with 24s in the rear and 22s in front so i figured i would ask
#392 |
Well I can not go any further until some parts show up for the rear suspension so I started on the rear gate's. I am changing over to a lift gate but keeping the barns doors for the lower half. They will have 180* pocket hinges so they will open out of the way. I am thinking about using small bear claws for the hatch and the two doors to lock to each other. The barn door bottom latches will remain. For the top of the doors I will have a 5' piece broke to match the profile of the piece I made. Doing it in a 5' piece then welding it to the doors as a 5'er then cutting the center gap will insure that everything stays nice and striate.
So for the lift gate I started doing the same mod that Frizzle Fry did for the top hinges and let me tell you he sure made it look easy. I spent the better part of the day and finally got the hinges half mounted. Kevin LFD Inc. [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() Last edited by Rokcrln; 03-02-2009 at 01:25 PM. |
#393 |
Looks great Kevin. I'm sure you've probably already noticed, but the factory liftgates do not curve at the bottom to match the curve in the tailgates and will require some metal work to make it look perfect. I didn't realize this until we had already painted mine.....
![]() r/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 03-01-2009 at 11:49 PM. |
#394 | |
Kevin LFD Inc. |
#395 |
Those hinges look somewhat familiar? Looks like you're putting them to good use!
Tony from Norcal |
#396 |
[QUOTE=Rokcrln;3173290]Is you truck a SWB or LWB and does it have leafs or coils?
For right now I will just be using the stock Truck Vortec fuel system that is on the fuel rails. Down the road I may swap over to the Corvette intake or a small air pumper ![]() Kevin, my truck is a SWB with coils, my plans for running the 5.3 are to use the least complicated method(s) out there, I got mine out of an 04 avalanche, I got all the wiring, even the gas pump out of the gas tank (it seems kinda big to fit a blazer tank) I like your rear tailgate/barn door set up, it kinda reminds me of a ford expedition. Great job ![]() |
#397 |
![]() Join Date: Jul 2007
looks great as usual
Chuck 68 ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
#398 | |
Now if you plan on running a hidden hitch out back than the tank I used will not fit. Your panard bar makes the space way to small. On my 70 SWB I have the tank mounted to the back of the hitch and still had to bend the front lip just to clear the diff cover and that is on a leaf spring truck. You are right the stock pump assembly is rather large, I will be using just the pump out of that same type of assembly. Kevin LFD Inc. |
#399 |
I have a radical idea!
As usual, awesome build!
Oh BTW, Uncle Jim might be pi$$ed he if he knew you had his number displayed to the world! ![]()
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
#400 |
