02-28-2009, 07:33 PM | #1 |
Keep On Keepin' On
Driveshaft...
I shortened my frame from long to short...I have my long bed two piece driveshaft...Will I be able to reuse this or I am going to find another driveshaft? What are my options?
07 Avalanche Z71 92 Mustang 5.0 GT (Triple White w/ 53,000 miles) 72 SWB Chevy w/ PS, AC, 350/350 Current Project ....In paint shop getting body/paint work done (Corvette Velocity Yellow)... http://67-72chevytrucks.com/vboard/s...d.php?t=157669 |
02-28-2009, 08:49 PM | #2 |
its all about the +6 inches
Re: Driveshaft...
it's 12 inches too long now... since you cut 12 inches out of the middle of the frame.
You can have it shortened, or locate a SWB shaft or shafts. |
02-28-2009, 08:55 PM | #3 |
the boat guy
Re: Driveshaft...
i would reuse trans yoke and weld yokes and have a one piece made if you can.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
02-28-2009, 09:02 PM | #4 |
Re: Driveshaft...
if going for a real low stance, 2 piece may be better. A 2 piece is truely a better set up, just takes quality parts to make it worth while.
02-28-2009, 09:02 PM | #5 |
Re: Driveshaft...
Unfortunately I've got some experience in this area. As expressed above you can use your front and rear yokes and have a driveshaft custom made. It really isnt that expensive. I paid about $200 to have my driveshaft lengthened two inches. I know that sounds like a lot but really what I'm getting is a new shaft with my front and rear yokes welded to it and balanced.
------------------------------------------------- Jim Garage fillers... 85 Chevy C10 Silverado LWB 07 Nissan Altima 2006 Mini Cooper S |
02-28-2009, 09:10 PM | #6 |
Re: Driveshaft...
I did what you did and I shortened my own drive shaft just took it out of the front that hooks up to the transmission. I split the weld to take out the yoke and shortened then re welded it is worth a shot. I thought it might vibrate at freeway speeds but nothing at all.
02-28-2009, 09:11 PM | #7 |
the boat guy
Re: Driveshaft...
a 2 piece is better but when working with 40 year old parts, buying a new slip, stub, and carrier bearing when you could just get a 1 piece shaft made doesnt make alot of sense to me
02-28-2009, 09:17 PM | #8 | |
the boat guy
Re: Driveshaft...
i have seen professional mechanics that couldnt properly install a ujoint if their life depended on it, much less try to weld in an end yoke straight enough to be useable.
02-28-2009, 09:31 PM | #9 |
Re: Driveshaft...
I share your concern, it was supposed to be temporary so I could take it to the dmv to be inspectedt, but it worked so good I ended up just leaving it.
