Baggin the rear on my 66 ???
So I am new to the board.. Here is my introduction post..... http://67-72chevytrucks.com/vboard/s...d.php?t=331302
I tore the bed off my truck today so I could start on my rear step notch... So my question with the rear air ride setup is I see guys air out and laying sheet metal using the rear stock control arms with bags. Is there a issue with binding going that route? I was thinking of going this route.... ![]() So anyone laying sheet metal on here with the stock suspension in the rear with a step notch? Thanks for any input or info....... six5..... Last edited by six5; 03-01-2009 at 08:04 PM. |
Re: Baggin the rear on my 66 ???
LOL my truck is a six5 not a sixsix....... I just sold a sixsix Impala and am stuck on the sixsix number........ Ha ha....
and a few others
this may help. If you're gonna use the stock trailing arms, your gonna have to cut the frame pretty close to the back of the cab. Spend a little time with the search feature and you'll find all your questions answered.
And, welcome to the board.
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
Bill thanks for the link and welcome. I actually found that link and many others but it's not what I was looking for. So maybe a common C notch and stock rear control arms do not work. I will stick with my original plan of the two link with pan hard bar...... Thanks.......
the picture above is a step notch, not a c notch.......
Hey Y'all!!
I think PrerunnerRob had done his truck with a step notch using the stock trailing arms(with quite a bit of modification) before deciding to crew cab it and change the entire setup. Try using the search.
Just hopin' I live long enough to finish something!!! |
thanks for the info.....
Resistance is Futile
I think you will have to step it, but the stock control arms will work if you use a block also. In the suspension section I just read some stuff about people making blocks with mild steel and aluminum to get a couple extra inches.
I think the panhard may be more of an issue than the trailing arms.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
Tags |
1965, air bag, air ride, bags, c notch |
