Old 03-02-2009, 03:01 PM   #1
NPilot1975
NPilot1975's Avatar
Putting the Pieces Together
I finally have stopped changing my mind and decided on what direction to go with my truck. It is a 71 GMC pickup currently with a 68 Chevy doghouse, the frame is a shortened 72 Chevy, and I am not sure what the SWB fleetside bed came from (only paid $300 for it around 5 yrs ago.)
I bought a 67 SWB frame to build up, so I wouldn't have to tear my truck down to build the frame. I c-notched it 3 inches and was in the process of building all the needed crossmembers, when I decided I really wanted to lay it out on the ground. I am working on finishing up the KP components notch. Once that is in, I am going to start laying out the triangulated 4 bar I have and once it gets to me I will be installing a Porterbuilt dropmember upfront.
The drivetrain is '95 LT-1 350/4L60E and 12 bolt rear with 3.73's. I am currently running 18x8 Intro Pentia's with 245/40R18's and 18x10 Intro Pentia's with 285/35R18's. If money allows, I am going to switch to 20x8's and 20x10's. I have a rust free cab to swap on, but need a dash for it and some other pieces. Still haven't decided if I am going to cut my current cab up to make one good cab (it has solid floors, but needs rockers and cab corners.)
Here are some pix and will post more as work progresses.
1972 Blazer body...need to get a thread started for the rest of the story
NPilot1975 is offline   Reply With Quote
Old 03-02-2009, 03:05 PM   #2
NPilot1975
NPilot1975's Avatar
Re: Putting the Pieces Together
Few pix of the Notch.
Old 03-02-2009, 05:35 PM   #3
Hart_Rod
Hart_Rod's Avatar
It's about freakin time! I didn't think you were ever going to start a build thread, . What parts of the dash do you need? I'm parting a 71 that has a decent dash. Let me know.
R/
Hart_Rod is offline   Reply With Quote
Old 03-02-2009, 06:28 PM   #4
NPilot1975
NPilot1975's Avatar
LOL It's about freakin time I actually worked on this thing. I actually need a whole dash. I cut the one in the cab I have just before where it is pinch welded to the cab. I thought the other one I had was the whole thing, but it was cut in the same fashion and I don't want to tack weld across the whole front of it. I can take a pic at some point if this doesn't make any sense. I also need the area where the rearview mirror mounts and the drivers side upper fender blind nut area. I will take some pictures next time I get over to my storage building.
When do you get out? Are you moving back this way? The move and setting up a new house has eaten up a lot of my time, but my goal is to have the chassis done by this summer and have the truck mostly complete before I leave. I should have a decent pile of parts to sell once I get this together and know what I do and don't need.
Old 03-02-2009, 06:50 PM   #5
Hart_Rod
Hart_Rod's Avatar
Post pictures of what you need in this thread and I'll see what I can come up with.
http://67-72chevytrucks.com/vboard/s...d.php?t=330731
We'll be headed back PCola in Aug/Sep. Official retirement will be Jan 1, 2010. I can haul the stuff back with me to save you some shipping, if you can wait that long.
R/
Old 03-09-2009, 11:59 AM   #6
NPilot1975
NPilot1975's Avatar
Little more progress this weekend. Got the notches welding in and the frame cut out. Then spent some time deciding how I am going to mount my 4-bar. Now I just need to get some more steel.
Old 03-10-2009, 12:23 AM   #7
nuke1
nuke1's Avatar
looks really good, i love your truck the way it is, but it never hurts to improve, i definetly know this.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 03-10-2009, 11:06 AM   #8
NPilot1975
NPilot1975's Avatar
I was originally going to build 2 one to drive and one to show, but have figured out 2 would be too many. So, I am trying to make this as show as I can and be a daily driver.
I wouldn't want to cover that chassis you built with a truck. You do some nice work. I was going to use your trailing arm build, but ended up deciding on 4-bar.
Old 03-10-2009, 12:15 PM   #9
VA72C10
VA72C10
VA72C10's Avatar
Great work....watching this one...
Old 03-15-2009, 10:18 PM   #10
NPilot1975
NPilot1975's Avatar
Made a little more progress this weekend. I built a bracket for the back of the rearend to attach the upper 4-bar mounts. Plans for this week are to finish boxing the frame and layout the rest of the 4-bar mounts. My wife and daughter are out of town so dad gets to play all week.
Old 03-15-2009, 10:20 PM   #11
NPilot1975
NPilot1975's Avatar
Few more pix. I still need to add some gussets for strength.
Old 03-17-2009, 09:21 PM   #12
99lsfm2
I was hoping for some new pictures to see how the camera works.
99lsfm2 is offline   Reply With Quote
Old 03-17-2009, 09:25 PM   #13
NPilot1975
NPilot1975's Avatar
You'll have to wait till tomorrow. I forgot the camera today and don't feel like going back out. I did get the frame boxed from the notches almost to the center crossmember. Hope to get most of the rest done tomorrow.
Old 03-17-2009, 09:38 PM   #14
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Gonna be a sweet chassis for sure. Nice truck and good luck with the build.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 06-23-2009, 10:18 PM   #15
NPilot1975
NPilot1975's Avatar
It's been a while since I made an update and have been able to sneak out to my shop a few times since the last post. I scrapped my original idea for the upper bar mount and made another. I just need to finish weld the upper bag supports and the rear suspension should be pretty much complete. The mounts on the rearend are just tacked on because I am using the 5 lug rear out of my truck once I tear it down. Few pictures below. Enjoy!
Old 06-23-2009, 10:20 PM   #16
NPilot1975
NPilot1975's Avatar
More Pix.
Old 06-23-2009, 10:23 PM   #17
NPilot1975
NPilot1975's Avatar
And more.
Old 06-23-2009, 10:25 PM   #18
Hart_Rod
Hart_Rod's Avatar
Looks sweet! I'll have a few more pieces for you in about a month, .
Old 06-23-2009, 10:25 PM   #19
NPilot1975
NPilot1975's Avatar
Last one.
Old 06-24-2009, 01:48 AM   #20
nuke1
nuke1's Avatar
that looks good, i like your second one a lot better. more clearance and will work good. glad to see it comin along nicely.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
Old 06-24-2009, 04:21 AM   #21
GR8-68
GR8-68's Avatar
Great looking work your doing there cant wait to see the finished results
GR8-68 is offline   Reply With Quote
Old 06-24-2009, 07:23 AM   #22
djracer
djracer's Avatar
Didn't you buy an orange bed from me? If so it was a 71 short fleet.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 06-24-2009, 08:47 AM   #23
my67chevytruck
Under Construction
my67chevytruck's Avatar
Nice progress.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 06-24-2009, 08:53 AM   #24
NPilot1975
NPilot1975's Avatar
dj,
yeah, I bought the orange bed from you. That should be what will cover up all my work.
Old 06-26-2009, 12:01 PM   #25
NPilot1975
NPilot1975's Avatar
Can't wait to see the Burb in person! I will be happier when I am ready to paint this thing (the whole truck not just the frame.)
