What the heck are these brackets?
Hello everyone. I am getting ready to finish the wire harness install and also a headlamp relay upgrade. The windshield washer bottle needs to go somewhere around the drivers fender and real estate under the hood is running out to mount all the goodies and I want a clean almost factory look for the headlight relay location. In other words, I don't want to put the relays where the washer bottle needs to go, and I cannot find where the washer bottle bracket needs to mount. There is also an extra bracket that I have no idea what it is nor where it goes. I also have a 1970 chevy lwb, but it has a different washer bottle and bracket that are on the passenger fender because it has an aux. battery(camper special). I'm going to attempt to post pictures of them both and maybe someone can help me out.
Thanks, James [IMG]<a href="http://s24.photobucket.com/albums/c34/cristinfreitas/?action=view¤t=100_0251.jpg" target="_blank"><img src="http://i24.photobucket.com/albums/c34/cristinfreitas/100_0251.jpg" border="0" alt="Photobucket"></a>[/IMG] [IMG]<a href="http://s24.photobucket.com/albums/c34/cristinfreitas/?action=view¤t=100_0253.jpg" target="_blank"><img src="http://i24.photobucket.com/albums/c34/cristinfreitas/100_0253.jpg" border="0" alt="Photobucket"></a>[/IMG] |
Old member
Re: What the heck are these brackets?
Images not working. I mounted my relays for the head lights down on the support by the old voltage regulator. I did away with it though.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 03-03-2009 at 05:49 AM. |
These are the brackets I was trying to show earlier...they look different than the 1970 lwb campers ws bottle bracket. By the way, I'm working on a 1972 K 10
Attachment 437269 Attachment 437270 Last edited by 72blue; 03-08-2009 at 12:51 AM. |
I think that bottom bracket holds the vapor canister.
72 Cheyenne Super 80 Silverado Blazer 2wd |
On my son's 72 4 WD Burb with aux. battery the washer bottle mounts on the fender liner. Here is a pic.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC Last edited by JimKshortstep4x4; 07-14-2009 at 12:54 PM. |
Sameyrasmea72, by Joe I believe you are right...Thanks for your input.
anybody know what the upper bracket is? JimLshortstep4x4, thank you very much for the detailed picture. Mine was not there originally as I did not have an aux. bat., but I may want to go that route because I am going to add one and want that stock look(sanitary and tasteful). Thanks again to both of you. James Here is the bracket in question. Attachment 437378 Last edited by 72blue; 03-08-2009 at 12:51 AM. |
