Old 03-04-2009, 12:00 AM   #1
khoult
67-68 to 73-87???
has anyone took a 67-68 body and put it on a 73-87 frame? if so, how?
khoult is offline   Reply With Quote
Old 03-04-2009, 12:37 AM   #2
metalman1968
metalman1968's Avatar
Re: 67-68 to 73-87???
Not that I have heard of, and was just thinking the same thing today. Dopping a 68 swb onto a 77 swb. I suppose anything can be done.
metalman1968 is offline   Reply With Quote
Old 03-04-2009, 01:17 AM   #3
thirdstreettito
Resident of Here
thirdstreettito's Avatar
It has been done, but it is VERY hard to do.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 03-04-2009, 07:35 AM   #4
Mudder
Mudder's Avatar
4x4's are doable and pretty easy.
Mudder is offline   Reply With Quote
Old 03-04-2009, 08:30 AM   #5
I see it done on 4wd frames.I don`t know why anyone would want to do it with a 2wd.The frames have some differences,but are basically the same.I don`t see any advantage.You`ll lose the coil suspension.I know the cab needs raised 2" for the bed to line up.So,4wd swaps are always higher than stock.The frame is longer in front,too.I`m not sure how you`d do the bumper.
Old 03-04-2009, 12:21 PM   #6
Skirkpat
Skirkpat's Avatar
It is like Cris Rock said, " You can drive a car with your feet, but that doesn't make it a good Idea !! "
Skirkpat is offline   Reply With Quote
Old 03-04-2009, 05:11 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
reposition the rear axle forward to make it back to the correct wheelbase, custom lift kit, probably fab up body mounts here and there.
On a 2 wheel drive it would look retarded. A 67 - 72 frame is flat, the 73 to date frames are not flat, that's why you need the custom lift kit.
